What kind of cast iron is a vise made of typically?
Results 1 to 12 of 12
    Jul 2019
    CANADA
    British Columbia
    27
    Default What kind of cast iron is a vise made of typically?
    The title says it all,
    I'm looking to machine the back edge of the vise, such that i have a parallel surface to be able to clamp on a vise stop.
    I wanting to anally calculate the exact proper SFM, just for fun, because my machine has a continuously variable spindle speed 0-5000RPM, with a (i assume) fairly accurate optical tach.w/ RPM Readout.
    I know any relatively normal rpm will do, this is mostly a question about what kind of cast iron vises are usually made of. Are all cast iron machinery and machinery related things the same type of cast iron?
    Mar 2017
    LATVIA
    916
    289
    522
    why would that matter for this 1min 1 off job? you can machine it at 5ft/min or 10rpm or whatever if the spindle motor has enough torque at such low rpm, it will still be quicker than wondering yourself about it and even more so when you spend time making pictures and starting a thread about it
    in any case, you see there is overlap with all 3 of you choices, take 100ft/min and you'll be totally fine, it's CI...
  3. Likes Illinoyance liked this post
    Mar 2005
    Kansas
    8,889
    643
    4594
    I would expect a vise such as that to be gray iron.
    Jun 2008
    Bellingham, WA
    4,621
    1140
    2633
    A good vise made in the last 70 years (since ductile iron came into general use) should be made of ductile iron. Grey iron has relatively poor tensile strength and fracture resistance. Ductile iron behaves a lot like steel. Malleable iron would also be a better choice for a quality vise than grey for the same reasons.
    For your purposes, the question is irrelevant.
    Denis
    Added: "The Kurt 4″ Double Station Vise is a High Density vise in an English configuration. The HDL Anglock vises are high density long vises with 2 clamping stations. They provide repeatable clamping to 0.0002″ and combine high density with heavy duty features. Designed on a rugged 80,000 PSI ductile iron body with steel components, they provide strength, rigidity and long term accuracy while absorbing machining vibration. Jaws for the Kurt Double Station Vise are available in the following options: Hard Jaws, Machinable Aluminum Jaws, or Machinable Ductile Iron Jaws."
  6. Likes sfriedberg liked this post
  7. #5
    Jun 2013
    New York
    1,082
    739
    612
    My bench vise is cast steel. Spark test confirmed that. 1943 Prentiss Bulldog, if anyone is wondering. Has US Navy markings.
  8. Likes dgfoster liked this post
  9. #6
    Jun 2008
    Bellingham, WA
    4,621
    1140
    2633
    There are even a few current makers like Yost who cast steel vises. The great majority are iron with crappy ones being grey and any decent iron vise being ductile.
    Denis
  10. Likes pavt liked this post
  11. #7
    Jul 2004
    Houston, TX USA
    32,613
    Quote Originally Posted by pavt View Post
    I can report my 18" shaper vise is cast steel - made by the serious folks at OHIO
    The double screw job and about 600 Lbs
  12. #8
    Jun 2013
    New York
    1,082
    739
    612
    Quote Originally Posted by dgfoster View Post
    There are even a few current makers like Yost who cast steel vises. The great majority are iron with crappy ones being grey and any decent iron vise being grey.
    Denis
    Wow I didn't know they were still around -- thanks for the tip!
  13. #9
    Aug 2005
    Toronto
    5,844
    3971
    4661
    the title does not say it all.....like what kind of vise?
    then again, I was able to speculate you probably weren't filing or hacksawing in FPM
    I don't think anyone can say what your vise is made of, not all brands are going to be same. If you know the make, look it up and see if they make any claims. Besides, for a one of job, does it matter?
  14. #10
    Feb 2010
    ch
    3,585
    297
    516
    such a cutting speed table is pretty much useles. cutting speed mainly depend on hardness. cast irons have a hardness between 100 and 500 hbn. you adjust the speed proportionally (roughly). no idea why grey iron should have the lowest speed, the carbon flakes add lubricity and break chips.
    (btw, the different kinds of ci frequently listed are somewhat missleading, as there are many sub classes and many castings fall inbetween. i suspect many (bench) vices are cast out of what they happened to put in the melting pot.)
  15. Likes pavt liked this post
  16. #11
    Nov 2010
    UNITED KINGDOM
    1,056
    208
    252
    Denis
    What is English configuration compared to US configuration?
    Is this just Imperial measurements not metric?
  17. #12
    Jun 2008
    Bellingham, WA
    4,621
    1140
    2633
    Quote Originally Posted by lionelt View Post
    Yes, it appears that they used “English” when most folks would have used “Imperial.”
    Kurt Workholding's 4" and 6" HDL manual vises are high density vises with English threads and are compact to allow for maximum workholding across a range of machining centers.”
    Denis
  18. Likes lionelt liked this post
