What Kind of Material for Thread on New Vice Design?
Results 1 to 5 of 5
    Jan 2011
    Kansas
    758
    55
    61
    Default What Kind of Material for Thread on New Vice Design?
    I have a customer that's developed a new heavy duty shop vice they are wanting to market. They are using 1"-8 grade 8 all thread for the screw. What would be the best material for the "nut"? We had some 4140 annealed laying around and tried that, but it does seem to have some trouble goulding. We put a big load on it and it got tight and once we had it worked apart the screw threads are kind of chewed up.
    Aug 2017
    Connecticut
    61
    10
    Steel on steel is never a good bearing longterm. Best bearing would be hardened steel screw and either cast iron or high nickel bronze for the nut.
  3. Likes Limy Sami liked this post
    Sep 2006
    SW Wisconsin
    680
    149
    237
    Stay away from 60 degree V threads, they are meant to lock at torque, not slide. Go with an Acme or square thread.
    Ed.
    Mar 2005
    Kansas
    8,333
    551
    4096
    Check out Green Bay Manufacturing for acme threaded rod and nuts.
  6. Likes Limy Sami, UptownSport, digger doug liked this post
  7. #5
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,878
    74
    910
    perhaps , some virtue...
    if they're going to make a commercial product, and they
    can't spec the materials..... it will be a huge failure,
    so don't bother until they get some answers as to what they're
    trying to accomplish, business plan,pre-market etc...
    mcmaster carr , or any other good source will have everything they need to sift thru to make it happen.
    USE PURCHASED PARTS!!! GODDAMMIT>
    you need that mind for proto work. if this is to be
    the next kurt or chick vise system..........the design
    will prevail over sourcing screwstock.
    a kurt leadscrew isn't particularly hard.
    once you're on QVTV, you can spec any material you choose.
    good luck
  8. Likes Pathogen liked this post
