What machine surfaced this cast iron table?
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Oct 2017
    New Hampshire
    97
    85
    21
    Question What machine surfaced this cast iron table?
    Hello,
    I've now got three tables with these similar "machining" marks on the surface. Third time's the charm, so here I am. WOC is about one inch, on all three. Linear, in a single direction. No visible tooth marks.
    Too wide of a cut for a shaper, no circular cutting marks from a mill, don't THINK you'd get that surface finish from a surface grinder...
    Additionally, what is this largest table that you see below? It has substantial webbing on the opposite side of the casting. All five sides appear to have been surfaced. Is it a surface plate for inspection/gaging? Just a table? Probably 600-800lbs, I found only a few markings.
    Let's discuss. I'm very curious now, and I'm certain someone here can enlighten me
    Jan 2007
    Mountain Home AR.
    128
    9
    74
    The best guess I have is that the tables were planed.
  3. Likes BuffDan liked this post
    Feb 2001
    Redwood City, CA USA
    5,106
    198
    1010
    Yup, planer. With a broad-nose finish tool. My dad had a workbench/layout table from Challenge Machinery Co. similar to what you show. Wish I had it, went to house clean-out guy.
  5. Likes JoeE. liked this post
  6. #4
    Virginia
    30,336
    7561
    9493
    Quote Originally Posted by steamandsteel View Post
    Hello,
    Planer. Circa 1950-52 Alzmetall drill press table is similar.
    Common as dirt long ago, less-so now.
    Intentionally tooled to "show" it's own tattle-tale wear-pattern if/as/when and where worn unevenly as well as to reduce "wringing" or stiction when positioning work atop it that wanted moving about in fine increments without arguments.
    Absent hand-scraping, it would be a "working" side of the shop layout and assembly alignment and fit-up aid.
    Bitchin' grand "work bench" for some folks, some trades, but most 'ere would find it a chore to mount it properly and avoid damaging it.
    "Inspection" plates WOULD be scraped to finer accuracy. Cast Iron, not granite, plates dominated up until they went seriously scarce, War Two priorities. That recent.
    A monument-maker then resurrected the stone plates as used by the ancients. I have one. A genuine "Herman" brown granite in Grade A. Bigger monument makers such as "Rock of Ages" followed suit in pinks and salt & pepper grey-whites, others in black granite & gabro. Granites & c. came to dominate inspection and layout, even certain types of speciality "machine" tables.
    Cast Iron still has its merits, but it is hard to compete on price with a billion or so years head start on stress relief of the materials that granite & such start OUR use of them with already "built-in"!
  7. Likes Hopefuldave liked this post
  8. #5
    Mar 2005
    Indiana
    4,615
    1190
    1071
    Yep, broad-nosed on a planer, no question about it.
  9. #6
    Apr 2006
    Manchester, England
    8,675
    1359
    5625
    I agree with the other guys, definitely planed. We used to call it " Flat Tooling ". Maybe a 1" wide flat tool with a large feed stepover on each stroke. Most guys would put a 0.0015" feeler under one corner of the tool to create a very slight saw tooth effect with a sort of pin stripe look. . As Thermite mentioned it makes moving larger components around the table easier.
    Regards Tyrone.
  10. Likes steamandsteel liked this post
  11. #7
    Mar 2006
    Vershire, Vermont
    2,206
    1473
    709
    Great finish for big bandsaw tables. Finished plywood doesn't stick to the table.
  12. #8
    Aug 2006
    Kansas
    2,213
    15964
    936
    That table top looks like what they called a "stone" in printing shops back in the "hot metal" type days, and I bet that's where that thing originated.
    Most every machined iron surface in our school print shop, and in the newspaper printing plant I worked at, had the exact same finish. Presses, paper cutters and tables.
    Planed.
  13. #9
    Dec 2008
    N.E. Illinois
    427
    101
    187
    Hey Thermite, like I stated before about granite surface plates. We use them all throughout our working career. Then, when we go to "The Great Machine Shop in The Sky" our widows can make our tomb stones out of them!
  14. Likes West-7 liked this post
  15. #10
    Feb 2005
    9,206
    14781
    11011
    So I saw this thread earlier today and I saw that pattern on the table, and I had
    never ever seen that before. Interesting.
    A few hours later I FINALLY cleaned off a cast table I had sitting around and gathering
    dust for a dozen years. Threw a DA to it so I could use it as a welding table and what
    do you know.
    Also related, I had the mating cast table until this morning. I loaded it onto
    my truck and gave it away, with 3 working drill heads on it. It was originally
    2 tables bolted together and total of 6 drills.
    And YES, I *GAVE* it away. I had drilled maybe 2 holes with it in a dozen years,
    and it was taking up room, and it was in too good of a condition to throw outside.
    I gave it to a good customer of mine, a fab guy. Less than half mile down the road,
    I'll probably see it at least 3 times a week for the next 10 years, and he'll get a
    lot more use out of it than I ever did.
  16. Likes eKretz, TeachMePlease, steamandsteel liked this post
  17. #11
    Mar 2005
    Indiana
    4,615
    1190
    1071
    Mighty kind of you Bob. That was a nice gesture that I'm sure he appreciated.
  18. #12
    Oct 2017
    New Hampshire
    97
    85
    21
    Quote Originally Posted by Tyrone Shoelaces View Post
    Regards Tyrone.
    Fascinating, Tyrone. It makes sense, so every inch or so there’s a very slight ridge to keep pieces from sticking to the whole surface. Metal planers are new to me, but seems like they’re quite versatile! Glad this mystery has been solved.
  19. #13
    Apr 2006
    Manchester, England
    8,675
    1359
    5625
    Compared with Plano-mills planers are much slower in production but on the other hand they are very forgiving of geometrical inaccuracies in the machine structure. Also a planed surface is also much easier to scrape than a milled or ground surface.
    Regards Tyrone
  20. Likes 4GSR, steamandsteel liked this post
  21. #14
    Jan 2014
    Utah
    626
    1585
    267
    ... a planed surface is also much easier to scrape than a milled or ground surface. ...
    Tyrone,
    That's very interesting. Please elaborate.
  22. Likes steamandsteel liked this post
  23. #15
    Apr 2006
    Manchester, England
    8,675
    1359
    5625
    Quote Originally Posted by Yan Wo View Post
    Tyrone,
    There's not much to elaborate about. Both grinding and milling processes create a sort of " glazed " skin on the surface on the work. Planing doesn't do that so your scraper bites in nicely straight away instead of skidding across the cast iron. Once you get under the " glaze " everything is equal but that takes a little bit of effort.
    Regards Tyrone.
  24. Likes steamandsteel liked this post
  25. #16
    Jan 2014
    Utah
    626
    1585
    267
    Regards Tyrone.
    I've learned something new! Thanks. Only 1,756,739 more facts and I'll know everything.
  26. Likes Bobw, steamandsteel, JoeE. liked this post
  27. #17
    Virginia
    30,336
    7561
    9493
    Yah think? Might find at a high multiple of that 7/8ths of the world is convinced ye've gone stoopider, even MORE boring.... or both....
    DAMHIKT!
    A.N Other reason is that a planed surface rats-out worn areas by the change to the pattern. Assessment can be faster and easier.
    Annnnd it is not an easy pattern to cheat on and try to duplicate to hide that wear. As "cosmetic" partial re-scraping or flaking has "now and then" been found to be.
    A ground surface may hide wear, and very effectively. Assessment can take longer.
  28. Likes Yan Wo liked this post
  29. #18
    Dec 2010
    Sydney Au
    482
    61
    63
    One of the steel mills here had a 60' wall planer for reconditioning, I'd imagine there'd be a reasonably hefty table involved there!
  30. Likes steamandsteel liked this post
  31. #19
    Jan 2014
    Utah
    626
    1585
    267
    Yah think? Might find at a high multiple of that 7/8ths of the world is convinced ye've gone stoopider, even MORE boring.... or both.... ...
    1,756,738 facts remaining.
  32. #20
    Virginia
    30,336
    7561
    9493
    Just have a care they do NOT include the nine billion names of God.
    My 'lectric bill is a tad onerous already.
