What material to make shifter handle?
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Sep 2012
    Cincinnati
    258
    5
    49
    Default What material to make shifter handle?
    For my anal 65 Fury 2 door cop car restoration with a 3 on the tree standard, I can't buy a handle and need to make it. It needs to be shiney plastic.
    I made 3 of them (was practicing) out of black polycarbonate and over time (from hours to months) all 3 cracked/split. The handle is pressed on to the shaft which has 2 nubs sticking out. The first ones cracked almost immediately in the are of the nubs, so I made it a looser fit. That seemed to have solved the problem.
    Gave the best one to the restoration shop and after a few months it totally split in an area not near the nubs. All 3 show some evidence of cracking.
    I tried making it out of Delrin, but it does not appear that Delrin can be polished to a good shine.
    Anyone have any suggestions for a different material?
    Unfortunately don't have pictures of the cracks readily available, but here is a picture of an original one.
    Jul 2006
    Hillsboro, New Hampshire
    8,502
    2053
    5915
    Black Delrin can be polished, but it should be machined with sharp tooling to as clean a finish as possible to begin with.
    Sep 2012
    Cincinnati
    258
    5
    49
    I found a picture of 2 that I made. Left one was a good one that I made and right is one already showing signs of cracking. The left one ultimately cracked also after a few months.
    Sep 2012
    Cincinnati
    258
    5
    49
    Can it be polished to a high degree (not sure of the proper terminology)? When I tried to polish the Delrin, I got it to shine but it was still a dullish black not like the results of the polycarbonate.
    Jul 2006
    8,502
    2053
    5915
    It may depend on your version of "shine". What methods did you use on your previous part?
    This older thread may help, some good advice, some "not so good"...
    Shining up delrin
    Jan 2005
    Houston
    5,886
    590
    2698
    Cool to have a C body with a three on the tree...
    I'd use metal and get it coated in Teflon black. To hell with plastic lol. Or better yet, use bone or horn.
    Mar 2017
    203
    100
    Ebonized fruitwood. Apple or pear is what i think they used to veneer old Engish ebonized clock cases.
    Nov 2005
    Hudson Valley, NY
    991
    615
    Try ABS. Cheap and shiny.
  9. Likes MrWhoopee liked this post
  10. #9
    Nov 2007
    marysville ohio
    9,617
    2762
    6401
    Make it out of 6061T6. polish it to a mirror shine then black anodize it.
  11. #10
    Dec 2016
    160
    26
    44
    Id look into some of the old "plastics" like paper micarta or maybe Bakelite.
  12. #11
    Apr 2004
    Modesto, CA USA
    7,186
    1226
    I wonder if the original was molded in place over the shaft. this would greatly reduce stress and the possibility of cracking. maybe bore it to a slip fit and fill with epoxy to install.
  13. #12
    Jun 2012
    Idaho
    3,166
    1749
    2064
    Metal,then take a pick of a variety of coatings.Really cool shit out there these em days
  14. #13
    Jan 2005
    Houston
    5,886
    590
    2698
    Yes, I am pretty sure the orignals were molded on the handle.
    The more I think about this, the more I like my bone/horn idea. While metal is usually better, in this case the coldness can be less than inviting. Most larger cities have a zoo that should provide an ample source for a variety of exotic horn. You only need a little.
  15. Likes Hazzert liked this post
  16. #14
    Aug 2008
    Sussex, England
    3,429
    12
    761
    Agree these things would have been moulded in place from some sort of thermoplastic resin. A completely routine process back in notes day. These days folk making similar control levers claim to use acetal resin based (POM) technopolymer, what ever that might be, and similar compounds.
    Bakelite and other phenolic resins are still used for highly polished knobs. If the knob is separate from the shaft rather than formed in place it is said that you must use a threaded insert. Cast phenolic resin can be polished after mating to a high finish. I imagine that the ultra fine abrasive papers could be used these days rather than the pumice stone most older references call for.
    Clive
  17. #15
    Sep 2002
    People's Republic
    3,908
    347
    2469
    polycarbonate is allergic to gasoline and other such things, which will cause it to crack
    what did you use for cutting fluid?
    make it out of anything and paint it gloss black and clear it
  18. #16
    Jan 2006
    Angier, North Carolina
    2,622
    1125
    990
    Quote Originally Posted by APD View Post
    I thought about ABS when I first read the OP ... but then I remembered that ABS breaks down fairly rapidly in UV. I think. Whether or not there would be enough UV getting through the car windows is another question.
  19. #17
    Sep 2002
    People's Republic
    3,908
    347
    2469
    Quote Originally Posted by awake View Post
    I think black ABS is probably OK
    Well, hey I just made a black ABS shield to cover a ldpe tank that the sun eats up, so I guess I will find out
  20. #18
    Aug 2012
    California, Central Coast
    4,089
    2234
    1605
    Dont press them on to the shaft, it seems the constant pressure will crack it no mater how light the press fit. Use some sort of epoxy in an oversize hole and your cracking troubles should be over. You might even cast the entire handle in place black epoxy?
  21. Likes henrya liked this post
  22. #19
    Oct 2009
    near Seattle, Washington, USA
    1,456
    501
    800
    How about a castable urethane?
  23. Likes awake liked this post
  24. #20
    Apr 2004
    Modesto, CA USA
    7,186
    1226
    Solid ,cast in place, gold should polish up nicely.
    Bill D
  25. Likes awake liked this post
