What Material to use for Casting Pattern
markz528
Hot Rolled
Sep 25, 2012
Cincinnati
I need to make the alternator bracket for my 65 Fury cop car as I have been unsuccessful in finding one (see picture of my first prototype pattern). It will be sand casted out of ductile iron. I have never had anything cast before.
Made the first prototype from oak. That did not go too well. Oak seems to be quite porous after machining, and it actually pulled some material in spots.
Made some adjustments to the shape and made the next prototype out of poplar. Again the finish is not great but no pulling and I would like to use a better material that will finish better.
Someone suggested Maple. I can get Maple but not that easily. Is Maple the right choice or is there a better material to use for a sand casting pattern that will be used to make 2 castings?
Honestly why not just machine it either out of Alu or a block of steel? Will be way cheaper than a 2 of casting cost.
There is more to a pattern than making a non metal look-alike
Like draft and shrink
After doing all that machining, why not just metal ones???????????
My grandfather ran a pattern shop. All the patterns were made with straight-grainad mahogany and finished with lacquer. Draft and shrink are critical. Was fillets were used to avoid sharp corners.
Jon
Price is not bad. Local foundry will cast 2 of them for $100.
The car is an anal restoration. Its a 1965 Plymouth 2 door cop car that my great uncle bought at auction in 1966. I am going through great pains to make the car as original as possible. It's sentimental to me. In my opinion a non cast bracket would just look out of place in the car. Unfortunately my great uncle converted to power steering and when he did he moved the alternator and threw the brackets out. Fortunately I have the alternator and a couple of the brackets.
I like the thought of mahogany.
I have minimum of 1/2 degree draft everywhere. Shrink will not be a problem with the tolerances I am dealing with. I did make a slight adjustment for shrink.
Jon
The pattenmakers where I worked usually used an imported wood that looked similar to mahogany, but was from southeast Asia. I have a few pieces, but I have forgotten the actual name. I have used maple for patterns.
Separately added fillets are usually made of wax or leather.
Wood patterns need to be sealed with lacquer, varnish, enamel or similar. The mold maker will also dust it with mold release powder before adding the sand.
Larry
I don't think 1/2 degree is enough draft especially on the deep section, too much chance of tearing the sand when pulling the cope & drag. I make a lot of patterns for a iron foundry and I try to keep a 3 degree taper.
Larry
Jelutong, if I spelled it right.
The wood you carve your pattern out of is immaterial. Especially for a run of 2 parts. Just fill the porous grain with putty or Bondo and varnish the heck out of it until it’s smooth. The most important thing you will need to consider using green sand is draft angle. 1/2 degree is not nearly enough unless you are using resinated sand which uses a resin binder to “glue” the sand together and create a much more stable mold. Typical green sand will require a minimum of 2-4 degrees of draft angle.
Draft angle depend on the hight
A draw spike tool is used for rapping the pattern gently the loosen it from the sand to assure a clean draw.
So if its low like half a inch you can even do with no draft
And for smaller items that will also compensate for shrinkage
For a run of 2 any wood will do if properly sealed
All patterns are sealed anyway AFAIK
Peter
...made the next prototype out of poplar. Again the finish is not great but no pulling and I would like to use a better material that will finish better...
Are you sure that was poplar? Poplar is a close-grained wood (which is preferable for a pattern) and should present no problems in achieving a smooth finish with common oil-based varnishes.
--Mike
