moonlight machine
- Nov 19, 2007
- marysville ohio
I need to make some wheel nut sockets for an old Indycar. Don't even suggest buying one, you will never find one like this. The area that grips the nut has 12 lobes and is almost 5" diameter, it is 6" long and uses a 1" sq. drive. The original one had a titanium bit that grips the nut bolted to an aluminum tube that had the sq. drive (made from EN 16, wtf is that?) bolted on with 12 3/8 socket head cap screws. It was a real cluster fuck and maintinence nightmare. I am going to make them from some sort of steel, maby 8620? The tube area will be only .060 to .090 thick. The area where the sq. drive plugs in as well as the lobes should be heat treated. What about heat treating a part with thick and thin sections. Any ideas on material or should I stick with 8620?
