What is meant by "optical or precision orientation" for locational position of drilled holes at the following link:
Machinist Drilling Mechanical Tolerance Capabilites Chart - ANSI Size Drilled Hole Tolerance, ISO Metric Drill Sizes - Engineers Edge
Do I have the following right? Looking at the "normal" tolerance, a positional tolerance of .016" could be done on a manual mill if you invented a fixture? A normal tolerance of .005" would require your mill or cnc machine to then have "optical or precision orientation?"
