What are my options to upgrade a MT4/grub screw spindle tool holder arrangement?
Trboatworks
Oct 23, 2010
Maryland- USA
I just picked up a patterns makers mill and it has no draw bar in the solid spindle and a MT4 taper with a grub screw to secure the tooling.
I am thinking the normal assortment of drills bits, end mills, face mills boring heads and bars etc.
What are the options to upgrade this to a faster and more flexible setup?
I have some split bushings which came OEM which convert to straight shaft in 3/4" and a 5/8" with additionally is bushed to 3/8" and 1/4"
I suppose if I just had a 1/2" and 1" bushing I would be in ok shape but would like something faster to use and with many multiples to have a rack of commons set up to use.
I would find it painful to make up those split bushings and I am not finding them to buy.
I am thinking Albrecht has a keyless chuck for end mills which could be used purchased for the largest straight bushing I can get which is probably 1"
I also need a simple drill chuck but an Albrecht keyless will serve with a 3/4" straight arbor.
This is the sort of tooling that came with machine.
That index face mill is mine and on a 3/4" arbor set into the 3/4" bushing that fits to the mt4 mill spindle.
8C21FAA3-5172-4B61-B3F0-304DE16AD057.jpgC370B92E-6E2C-4158-924D-2CD2F00060BC_1_201_a.jpgC7B47E26-D919-4B06-81D6-CE1E09B7A449_1_201_a.jpg8446DE25-BEFF-44EB-988F-FD6416CF3AEF.jpgC0B40592-FE8A-4688-97CA-AB205098A209_1_201_a.jpg
This is the spindle- sorry for the small pics- I don't seem fluent enough to control when these show up as larger or thumbnails...
Or thumbnails which are much larger when selected- how is that done- it is hit or miss for me- sometimes large, sometimes not.
^ Did you say you had a lathe ? :D
I would find it painful to make up a bunch of those split collets- I could do it sure but they should be ground and hard to get reasonable TIR?
I don't have that capability in the shop.
As a last resort I will turn something and would no doubt get usable tooling- FAR sooner will be a look see at Ebay UK to buy up some old tooling.
I can get by for a while on the 5/8" and 3/4" collets I have for the spindle.
I would find it painful to make up a bunch of those split collets ...
I was thinking more along the lines of making one spindle that held some NMTB taper.
Alternatively, you could make a permanent TG or ER or whichever you prefer collet holder that would be a permanent fit in the existing spindle. But I think a custom spindle would be cleaner and maybe easier.
