sgt panties
- Jul 22, 2013
- NC
what I would like to know is how do you replace those pos's.
Seems like a lot of times the life expectancy is short
I'm not sure what other folks call it but I call it a button oiler. . .
There is a 'button type' lube fitting, usually used with grease, but occasionally in years past also with oil. It is normally used where high pressure injection of the lubricant is required. The fitting has a well-defined neck which accepts the injector much like a shell holder used in reloading.
Hi, I have a Chinese lathe with about 20 flush style "oiler ports" as in the picture. This is probably a very basic question but it's difficult to research if you don't know what the darn things are called. So... what are these called and how do I oil them?
Is there a common and off the shelf tip that cleanly oils these little guys?
Not a hack or a lot of handheld force, something made to do the job that a ten year old can handle and not make a mess?
Bob
In the USA, the name, as stated by Gits, the major maker, is "ball oiler."
Style GB Ball Oiler | GITS Manufacturing
Most any oil can with a small tip can depress the ball and force oil past it. So no special equipment is needed.
Larry
In typical American fashion, NO F'ing Metric ones available. When will you guys wake up???
Wake up, mate. You only have to look at their vast selection to find them: Metric Ball Valve Oilers | GITS Manufacturing
They even do BSP threads.
Larry
If YOU want Metric fittings...Why don't YOU go get them ?
Instead of complaining about how another country doesn't have them ...
Bob
Notice
