I lost the arbor nut for my table saw. I am trying to figure out the correct size, so I can get a replacement. I measured the shaft / arbor that receives the nut. The arbor / shaft diameter measures 15.9mm. The thread pitch is 2mm. What size nut do I need? Also does left vs right hand nut matter?
It’s a craftsman table saw. Model number is 351.221160. The label on the saw reads 5/8 blade arbor. I’m assuming it’s a 5/8 nut? Just not sure about the thread dimensions. Coarse vs fine. Right vs left, etc
