What is this Starrett Gage for?
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Sep 2006
    Stillwater, Oklahoma
    1,231
    77
    632
    Default What is this Starrett Gage for?
    Someone I know asked me about this gage, which someone gave him, but he doesn't know what it's designed for. My first thought was a cylinder gage, but on second look I'm not so sure.
    The indicator is a tenths reading head with .025" travel. The head also has two spring loaded buttons adjacent to the plunger. In the right end of the case is a foot which has the rim on the bottom relieved to leave three feet and the rods fit into the foot and the top of the gage head. Since the rods are in roughly half inch increments it can't be general purpose since there's not enough travel. In addition, the two spring buttons are flat faced, not rounded so it wouldn't adjust to a bore. Jig borer setup and rods maybe?
    Feb 2008
    Utah
    2,867
    Sure looks like some kind of bore gage.
    Dec 2007
    N.E. oHIo, USA
    2,357
    1371
    Is there a Starrett number on the indicator case or on the wood box?
    Rex
  4. Likes Tozguy liked this post
    Oct 2002
    Kansas City, Mo.
    6,416
    202
    1830
    Kind of looks like a modern version of their old strain gauge.......
    Feb 2012
    Sunny San Diego and Lewis County, WA.
    1,203
    247
    461
    Bore gage set? Are you sure one end of the stems is not radiused?
    Sep 2006
    1,231
    77
    632
    Can't be a bore gauge. First clue is that the spring loaded feet on either side of the indicator plunger are flat, in line, and protrude past the plunger end. So the gauge has to be pressed down to register and won't accommodate a curve. Second possible clue. A rod in the opposite end also isn't radiused, and if the foot component is added you've got a wide flat surface opposite the plunger.
    I didn't see a Starrett number but I should look more carefully when I'm back by there. In fact, I'm not sure I remember a Starrett name on the box so it might be a third party product using a Starrett gauge.
    Sep 2006
    1,231
    77
    632
    Quote Originally Posted by rivett608 View Post
    Hmm. The spring pads might be calibrated springs such that compressing to a gauge zero equates to a certain force? That might be possible. The tenths indicator doesn't mean tenths, just that over a short distance spring compression force changes a lot. I'll consider that.
  9. #8
    Oct 2012
    Washington
    1,064
    889
    729
    I’m thinking a gauge to check parallel of two surfaces. Maybe even made for a machine tool builder.
  10. #9
    Sep 2006
    SE PA, Philly
    5,277
    980
    1746
    No idea, but I'm thinking the grooves on the rods, at different distances, are a clue. Any idea of what they are there for?
  11. #10
    Mar 2013
    New York
    3,803
    2770
    2426
    Lets get a pic of the back of that gage please.
    Three pads on that base makes me think that its trying to sit flat on something which would be relevant in checking height/depth.
    Another guy here was thinking it was to measure travel on the old manual masheens
  12. #11
    Aug 2004
    Lincoln, Nebraska USA
    69
    12
    Quote Originally Posted by bosleyjr View Post
    I suspect those are joints where shorter rods have been screwed together.
  13. #12
    Jun 2008
    Bellingham, WA
    3,871
    926
    1999
    Is that misprint saying the rods differ in length by .500 and not .050? I would have thought the grooves were a simple code for x, x+.050, x+.100, x+.150, x+.200 The spring loaded plungers could push a gage block onto a given surface further increasing the measuring range of the device. Must measure two parallel flat surfaces and most likely horizontal planes--like the distance "between the floor and the ceiling." The round three-footed pad goes on the "floor."
    Denis
    Last edited by dgfoster; 03-19-2014 at 08:45 AM. Reason: changed "shim" to "gage block"
  14. Likes allloutmx liked this post
  15. #13
    Feb 2005
    Owl's Head, Maine
    2,182
    340
    575
    All speculations will change to a definite identity when you find the Starrett item number.
  16. #14
    Feb 2010
    somewhere in Illinois
    1,159
    139
    312
    Starrett tools have an ID # on them somewhere. Find it and contact Starrett for tool use.
    Could it be a depth gage?
  17. #15
    Jun 2008
    Roanoke, VA
    651
    191
    243
    Do the rods fit into the back? It looks like it could be a squareness checker, the indicator could mount in 1/2" increments above base and the spring pads could square the indicator to the surface being checked in reference to the round base.
  18. #16
    Jan 2013
    Plainfield, Indiana, USA
    1,696
    1274
    913
    I don't think that is a Starrett gage, just a Starrett indicator. What does this look like when you assemble it? Pic?
  19. #17
    Sep 2006
    1,231
    77
    632
    Well, I ran out today and looked a little more without getting a lot more illumination.
    The box is clearly printed Starrett on the top but no other markings on sides or bottom.
    The back (or sides) of the device doesn't have any number either but here's what the back looks like. Spring loaded pads on either side of the plunger are flat and protrude past the plunger so have to be compressed a ways before the indicator registers.
    This is what the foot looks like on the underside for whatever that means. At the least it's intended to register on the face of something.
    Some people asked about grooves in the rods. It's actually different length rods stacked in the case. I pulled a couple to look at the ends and that's interesting too. They're not ground or lapped. Flat ends with some showing vestiges of turning marks so there's no precision to them, just spacers somehow.
    I don't know anything about the force gauge referenced in an earlier post but the high precision indicator coupled with the low precision rods suggests measuring something other than actual length. It's possible too that since it seems to be assuredly a Starrett product but doesn't carry a number, it might have been specially produce for some mfg but was never a catalog product.
  20. #18
    Oct 2012
    Washington
    1,064
    889
    729
    Quote Originally Posted by TGTool View Post
    I'm with you on this. I still think it was to check how parallel two surfaces were to each other. Could have been built for a machine builder. The fact that the rods are not ground or lapped makes me think it was only a reference and not intended to measure an actual dimension.
    I hope you are able to find out what it is, I'm curious.
  21. #19
    Sep 2007
    Northern Illinois
    2,910
    1615
    1734
    I may be way off base here, but is this a setup for a positive displacement indicator on a machine table, similar to what jig bores used before the days of DRO's? It seems the indicator could be held in a stationary fixture by the spring plunger pads, while the rods went through a hole to a target mounted to the table; the rods being added of subtracted for distances greater than the indicator travel.
    Dennis
  22. #20
    Jan 2006
    Portland, OR
    133
    39
    6
    Dang i was hoping the mystery had been solved by now.
    Hoping someone pops in and can answer this for sure.
