Forrest Addy
- Dec 20, 2000
- Bremerton WA USA
First of all, this thead I'm starting may be of interest to some but few have a need to delve into measurements finer than 0.001." So follow the discussion but unless you have a need to calibrate or certify mechanical masurements most of my commentary is intended for the theoretical minded and the accuracy junkies.
I refer to "dial indicators" and here I mean those with a conventional round face, radial plunger, and clockwork guts. Indicators that sense with a lever arm or electronics are not included in my comments.
The on-going thread about straight edges and flats and the need for highly sensitive dial indicators got me looking over the market. There's plenty of 0.0001" graduated indicators available both in the new and used (read auction) market. Some have quite a long range of travel. Those who intend to read dial indicators down into the millionths range will need to pay very close attention to short coupled stiff set-ups and temperature differences.
Anyone who's ever dealt with repeatable, certifiable, highly accurate measurement knows to treat dial indicators as comparative instruments. You set a comparative instrument by adjusting the zero on a dial indicator to a reference. The reference standard may be a certified gage or a stack of Jo blocks. It may also be used to register departure from the linear axis of a machine tool provided reversal error cancelling technique is used to separate work error from machine tracking error. Regardless the zero on the indicator dial is the target and all departures of the needle from zero representing tolerance band or out of tolerance are taken on faith in the indicator's short range accuracy or by setting to another tolerance reference.
So the message is: don't read a long travel 0.0001" graduated dial indicator and expect the dial reading to correspond to the actual distance traveled without checking it by means of length standards or other references. 0.0001" is an almighty small distance and taking readings from dial indicator's for actual data collection of linear motion is taking a lot for granted.
I gathered my 0.0001" reading dial indicators and set up a test rig. Some of these indicators were frankly beaters (one a dud I did not test because of a stuck plunger), most were in good shape, and two were new in the box. Using the measuring head of a large micrometer as a means of offsetting accurate distances, a hunk of iron for a framework, and a welded tab drilled and set-screwed to accept an indicator barrel I made up a quick and dirty dial indicator inspection station.
My shop was at 54 F degrees for the duration of my experiments. Most measurements and data points were short distance where environmental temperature variations of less than a few degrees represented error in the millionths and thus negligable.
Most all my indicators performed well when cycled within their range although reverse repeatability seemed to suffer in proportion to neglect and the time since the last attention from the instrument tech. If I dithered the set-up with a tapping pencil the reluctant movements settled into conformance with their accuracy specs.
Most of my 0.0001" indicators were honest in that if I dialed off 0.0250," the dial reading was 0.0250." Size of the indicator dial (I have AGD 1 thru 4 indicators in my collection) doesn't seem to have an effect on accuracy although naturally the larger dials are more easily read from a distance. The jeweled mevements were definitely smoother and more responsive and required less dithering to settle the movement.
Two of my beater indicators had hesitations on their movements. A flush with lighter fluid (my fav solvent for all things small in scale) and a blow out with canned air fixed one but the other (a very nice Federal E3BS-R2) seemed to have damage to the plunger rack.
I'm not getting into brand names except to say that Starrett, Mitutoyo, and Federal are represented. All performed equally well having regard for state of neglect.
One new in the box dial indicator was a cheap ChiCom copy of the famous German built indicator sold under a variety of names for many years, most recently, Mahr. These indicators sell for $250 to $600 over the counter and are distinctive because of their semi-circular case shape and 180 degree reading dial. This ChiCom copy indicator is sold by www.shars.com and has a +/- 0.002" range graduated in 0.00005." It is jeweled and the works inside were of brass.
If I'm any judge, the Shars is a fairly well executed knock-off of its prototype. It sells for $115 from the catalog. It a features shock-proof movement and low plunger force. If any are looking for a budget sensitive dial indicator I would give this one a qualified plug.
My day of monkeying around has shown me that 0.0001" indicators are quite rugged if fitted with a shock resistant mechanism, quite fragile if not. If they work at all they hold their accuracy well.
When using sensitive indicators one should reckon with all the factors that haunt precision measurement and take steps necessary to reduce errors to a minimum (dithering, watching environmental temperature, handling heat input, stiction, deflection (particularly in the set-up), cosine error, repeat zeros, and the others). A nice stiff dial bore gage might seem to offer bullet proof readings tempting one to split "tenths" but trust me: take the final readings with a reference check to the gage block stack you have next to your work station - and don't forget temperature difference between the work, the bore gage, and the setting reference.
[ 09-22-2006, 01:13 PM: Message edited by: Forrest Addy ]
