What steel to use for dies to heat treat? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Aug 2013
    Chicago, IL
    909
    622
    345
    Our die makers use A2 and D2 for almost all their projects...D2 for punches, A2 for forms. So my guys would recommend A2 for forming wire. Very little deformation during HT so you don’t really have to leave much or any for final touch up afterwards. 4340 can squirm on you after HT. Like Roger said, though, 1/2 ton may not be strong enough. Good luck!
  2. #22
    Dec 2009
    Australia
    34
    6
    Default Recon you need a bigger press
    As others have said already, recon you need a bigger press.
    Somethin like the attached pic would do. This is similar what I'm running at the shop.
    Availabilty: down here in OZ, at least, they are pretty easy to come by secondhand.
  3. #23
    Oct 2005
    16,087
    Quote Originally Posted by MattiJ View Post
    If you are just bending mild steel wire to funny shapes the mold is not much stressed at all. Without having a any clue what you are actually forming its hard to say how much stress and wear the mold or form is going to experience. Have you tried to make the mold from "ordinary" structural steel and if yes how long it lasted in the use?
    Use stock dowel pins to form over. Off the shelf and plenty hard.
