What tablesaw blade to cut thick plastics?
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Sep 2007
    Washington
    5,093
    171
    1439
    Default What tablesaw blade to cut thick plastics?
    Hi guys,
    I need to saw up a bunch of 1" ABS. I have been using an 80-tooth triple-chip blade which works well on acetal, but it melts the ABS. I figured I'd try some etching with fewer teeth.
    Anybody got something specific they have, that works well?
    Thanks, and regards.
    Mike
    Mar 2012
    Geilenkirchen, Germany
    2,255
    1376
    1142
    Your problem is not the blade, it is your blade speed. A table saw is way too fast.
  3. Likes Darin101 liked this post
    Sep 2007
    Washington
    5,093
    171
    1439
    Quote Originally Posted by steve-l View Post
    ... and yet there it is . That's the tool I have. Horizontal bandsaw can't rip strips from a 4' long piece of stock.
    Regards.
    Mike
    Jul 2008
    Gainesville, FL
    634
    773
    108
    Is your table saw single phase or three phase? If the latter, I installed a VFD on one a few years ago for the same purpose and it worked pretty well. I know it's not what you asked, but it's an option...
  6. Likes John Welden liked this post
  7. #5
    Mar 2009
    Washington
    7,857
    5773
    10153
    Next time order it precut. Tap plastics will do it for cheap.
  8. Likes Philabuster, Bobw liked this post
  9. #6
    Sep 2009
    Apex, NC
    1,440
    721
    I recently cut up a fair amount of 5/8 ABS (and thinner) with a 50 tooth, 1/8 thick (carbide) Freud combination rip/crosscut blade (it stays on the saw (an old General 10" tablesaw) a lot)--worked fine, no melting. 80 tooth finish blades are probably too fine, and have very little set/clearance...YMMV. Cheers
  10. #7
    Jun 2006
    Near Seattle
    4,644
    2869
    1227
    I've seen tap plastics cut plastic on what looked like a pretty ordinary table saw, I don't recall blade speed or type (was in another room looking through a window) - maybe call them up and ask?
  11. #8
    Feb 2005
    Akron, OH
    1,800
    271
    1340
    You want a straight tooth ripping blade. A dedicated ripper with deep gullets and something like 20 teeth.
    ATB blades are designed to shear grain. They push the chips towards one side and then towards the other. TCG are designed to not chip out laminates. They push the chip towards BOTH sides to keep the material in compression. You don't have grain and you want to keep the material away from the sides and not building up. Straight tooth, deep gullets, few teeth, and no anti-kickback geometry to rub on the material.
    Something like this
    https://www.amazon.com/gp/aw/d/B0000...ID=51lMcvR0fuL
  12. Likes TeflonDave liked this post
  13. #9
    Dec 2009
    SF Bay Area
    108
    15
    10
    There are blades made especially for plastic. If you think the speed of the blade is too high, you might see if a smaller diameter blade fits your arbor.
  14. Likes wawoodman liked this post
  15. #10
    Jan 2007
    Norfolk, UK
    18,359
    13902
    13864
    If its melting Fine grain - have you tried feeding it really hard, .....winding the blade up to have fewer teeth in the work will help a lot.
    Depending on their use, plastic circ saw blades can lose their edge (especially if you've chopped a few bits of ally without changing the blade - not that you would of course just saying, and ABS needs to be really sharp, ...have a close scrupey with an 8 or 10X glass.
    And of course coolant - even a squirty bottle of water and dish soap can make a hell of a difference ..I've used a pump up garden insecticide type sprayer at the finest mist to very good effect, ...........and by the time the ''wind'' from the saw blade and chips are down the chute there's very little mess - easily cleaned up by cutting up some dry pine boards - think kindling
  16. Likes specfab, Kohms10, wawoodman liked this post
  17. #11
    Dec 2007
    Central Ohio USA
    3,772
    68
    1697
    Fiber cement blades have as few as 6 teeth, and not much rake. There's also been a recent thread (regarding cut finish) with a lot of discussion and sources re: blades for plastic.
    Chip
  18. #12
    May 2004
    Vista, CA
    984
    255
    274
    Is your blade sharp? If it has been through a lot of use it may cut wood ok but plastic there might be too much friction with a less than sharp blade. JMHO
  19. Likes Limy Sami liked this post
  20. #13
    May 2005
    AZ
    2,320
    211
    789
    Yes, ABS will melt more easily than a lot of other materials. As others have noted, fewer teeth would be an immediate help. I have used 60T triple-chip blades frequently on thicker materials to assist with cooler cutting, and have gone to 40T on a few occasions (3/4 nylon, for instance).
    As Limy Sami notes, higher feed rate will help to accomplish the same thing (sort of), and yes, raising the blade to get more air cooling will help (a little). If you have a spraymist setup, that could be a large help in temp control. Mounted under the table works best for convenience if a semi-permanent installation, otherwise you could stick it on the fence with a mag base. Smaller blade dia will obviously lower the SFM, and with ABS not being too brittle, you could probably use an ATB blade from Home Depot (7-8", maybe 24-32T), and achieve "OK" results.
    I use a similar 80T triple-chip 10" dia blade on my saw for cutting aluminum and plastics, and as Limy Sami (again) notes;-), the aluminum cutting takes a toll on tooth sharpness...I have a separate blade I keep just for plastics, but often don't want to bother changing the blade if "it's just a few cuts". Sometimes turns into "why the hell didn't I change this blade out..."
  21. Likes Limy Sami liked this post
  22. #14
    Sep 2007
    Woodinville, WA
    1,774
    205
    372
    Another option.. slow vertical band-saw (you know which one I mean ), coarse blade. Clamp a 2x4 for a fence. As above, ABS is tricky - melts easy with friction
  23. Likes Blazemaster, EPAIII liked this post
  24. #15
    Dec 2007
    Massachusetts, USA
    802
    257
    546
    Quote Originally Posted by Finegrain View Post
    Hi guys,
    Mike
    You don't mention what the finish needs to be. Is this just a rough cut or does it need to look good?
  25. #16
    Nov 2008
    Madera county california usa
    2,381
    21
    588
    We did some plexiglass long ago and was advised to place blade backwards so it would scrape the plastic instead of cut it.
    Worked great.
    Use a very sharp carbide tipped blade and gentle feed.
    Wide cut meaning carbide inserts wider than saw plate as this reduces friction of the blade.
    Experiment with depth of cut as the angle depends on the blade and material but there will be a sweet spot.
    Sent from my SAMSUNG-SGH-I337Z using Tapatalk
  26. #17
    Oct 2014
    Maryland
    2,406
    1717
    1828
    Quote Originally Posted by SwarfsUp! View Post
    best plastic blade i ever used is from forrest worth the money, feed as fast as you can
    dee
    ;-D
    No Melt Saw Blades for Plastic Sheets and Extrusions -
  27. #18
    Sep 2007
    Washington
    5,093
    171
    1439
    Quote Originally Posted by Lakeside53 View Post
    Thought about that, but I don't want to tie up Mark's saw with my production work .
    Regards.
    Mike
  28. #19
    Sep 2007
    Washington
    5,093
    171
    1439
    Quote Originally Posted by jlrii View Post
    Cuts need to somewhat straight so the Talon Grips grip evenly. ABS is soft enough that if I have to squeeze hard with the Talon Grips to make up for uneven edges, the material will extrude away from the grippers and I make a little kaboom .
    Regards.
    Mike
  29. #20
    Sep 2007
    Washington
    5,093
    171
    1439
    Quote Originally Posted by dcsipo View Post
    dee
    ;-D
    I ordered the Amana version, will see how that does.
    Regards.
    Mike
  30. Likes TeflonDave liked this post
