What are these reamers for? (stubby reamers with Morse taper shanks)
Results 1 to 14 of 14
    Oct 2014
    Arkansas
    175
    60
    17
    Default What are these reamers for? (stubby reamers with Morse taper shanks)
    Hello. These two reamers came along with some machining stuff I bought a while back. Will you experts please let me know what these might best be used for? I'm trying to decide if I should keep or sell them. The shanks appear to be Morse Taper #2, or at least they fit snugly in my 10EE tail stock quill. Surely they're made for a different application, though, since the flats can't be used to prevent them from rotating by the stops in the quill (since the reamers are so short).
    Here are more photos:
    stub reamers - Google Photos
    Thanks in advance,
    Josh
    Feb 2006
    Indiana
    14,092
    827
    4821
    If there is a hole through the center, they are counterbores. You took a bunch of pictures, but all of the side view, so no way to tell if they have a hole.
    Larry
  3. Likes boslab, paroikoi liked this post
    Aug 2015
    Illinois
    1,753
    1372
    749
    Larry was quicker than I was. Shanks are stub Morse taper. Counterbores have a square end, reamers have a chamfer.
  5. Likes paroikoi liked this post
  6. #4
    Oct 2014
    Arkansas
    175
    60
    17
    Quote Originally Posted by L Vanice View Post
    Larry
    I never said I was smart...
  7. Likes Dupa3872 liked this post
  8. #5
    Apr 2004
    Modesto, CA USA
    8,939
    1771
    Note the tang has nothing to do with torque it is just to help eject the tool.
    Bill D
  9. #6
    Jun 2020
    South Carolina
    83
    32
    28
    I’m pretty sure these are taper pipe reamers. You would use them before tapping
  10. Likes ronf, Matt_Maguire, CatMan liked this post
  11. #7
    Oct 2014
    Arkansas
    175
    60
    17
    I just checked, and they are not tapered.
  12. #8
    Jan 2005
    Victoria, Texas, USA
    4,887
    3603
    1397
    Skully-Jones used to make holders that held these as well as counter bores with this short taper shank. There may be a couple of other companies that made them too. IDK. This stuff is pretty much obsolete unless you can find a holder. The adapter holder usually has a full morse taper shank on them. They do appear in epay once in a while. Ken
  13. Likes paroikoi liked this post
  14. #9
    Jul 2004
    Houston, TX USA
    32,456
    I have a pile new, but different - cross hole thru straight shank. They turned out to be production reamers for lifter bores in Mopar V8 cylinder blocks
  15. Likes 4GSR, JoeE., paroikoi liked this post
  16. #10
    Oct 2014
    Arkansas
    175
    60
    17
    Thanks, all.
  17. #11
    Mar 2005
    Kansas
    8,781
    630
    4512
    There is important information on the shanks. We could help you a lot more if you would simply list the information on the shank.
  18. #12
    Oct 2014
    Arkansas
    175
    60
    17
    Quote Originally Posted by gbent View Post
    That's why I took all the photos, as mentioned above. You're right, though, that I should have transcribed it here. Here goes:
    930-27205-66 BCCO
    M2 DIA. .9998
    DHM282-6 ID514566
  19. #13
    Mar 2005
    Kansas
    8,781
    630
    4512
    Barber Colman Company, perhaps? The 4 digit size suggests they are just standard reamers with a short shank, probably for use in a radial arm drill with an adapter that allows changing without extending the quill.
  20. Likes paroikoi liked this post
  21. #14
    Oct 2014
    Arkansas
    175
    60
    17
    That would make sense. Thanks for the explanation.
