What thread pitch is this?
Results 1 to 15 of 15
    Nov 2013
    Washington
    32
    57
    Default What thread pitch is this?
    I'm trying to figure out the thread pitch for the knob of an airplane's altimeter. I thought it might be 4-40, but it's finer than that. That's the finest standard pitch I can measure. I checked with my metric gage and .5mm looks like a pretty close match (although I'd be surprised if it's metric, but who knows?). The shaft diameter is about .113".
    Any ideas what thread this might be?
    Jay
    Feb 2006
    Indiana
    13,927
    801
    4682
    It may be 4-48, an old standard that you should be able to find a tap and die for from Victor.
    Try your 24 pitch gage and see if it hits every second thread.
    Your .5 mm is 50.8 TPI and .529 mm is 48 TPI.
    Larry
  3. Likes Screwmachine, birdus, sfriedberg, Bobw liked this post
    Jul 2005
    Newcastle, Australia
    621
    170
    4-48 is an ASME thread; it is, as the description implies, 0.112" dia x 48tpi.
  5. Likes birdus liked this post
  6. #4
    Sep 2002
    People's Republic
    6,082
    723
    3755
    Kudos for giving virtually no useful information in you question
    'what' airplane
    'what' brand gauge
    BA threads are another instrument thread
  7. Likes sfriedberg liked this post
  8. #5
    Feb 2006
    Indiana
    13,927
    801
    4682
    'what' airplane
    'what' brand gauge
    The British 6BA thread is .110 inch x 47.9 TPI and has a unique profile. A 6BA screw would probably go into a 4-48 tapped hole and be slightly loose.
    So the instrument maker's identity would help figure out what sort of thread it is.
    Larry
  9. #6
    Nov 2013
    Washington
    32
    57
    Hey, Larry.
    This one has a Cessna label on it, but I also have one that is from a Luscombe which appears to be the same size. As you suggested, I tried a 24 TPI gage and it appears too course. I'm going to give a local avionics shop a jingle and see if they have any ideas.
    Thanks for your help.
    Jay
  10. #7
    Jul 2005
    621
    170
    The thread reference that I use shows a few in the vicinity of the measurements/estimates;
    Column C is the size designation, D is the name, E & F are the diameter in inches and mm respectively and G & H are the pitch in tpi & mm respectively.
    It's probably obvious that M is the thread angle.
  11. Likes birdus liked this post
  12. #8
    Jun 2013
    CANADA
    British Columbia
    65
    19
    36
    Also, you can accurately measure the pitch by putting a dial indicator on the top of the screw and measuring the amount of movement for one turn.
  13. Likes birdus liked this post
  14. #9
    Nov 2013
    Washington
    32
    57
    For anyone who's interested:
    I have an altimeter that came in a box of parts that came with a project plane I bought. It's labeled:
    Cessna
    United Instruments, Inc.
    Wichita, Kansas
    Made in Japan
    The thread of its adjustment shaft is M3 x .5.
    The altimeter that's out of my Luscombe (the instrument in question) is labeled:
    Type MB-2
    U.S.A.F Stock No. 6080-A80MB
    Aerosonic Instrument Corp
    Cincinnati, Ohio
    The thread of its adjustment shaft is 5-44.
  15. #10
    Nov 2003
    5,972
    213
    2059
    Oh for Pete's sake. 4-48 is just as UP TO DATE as a 4-40, a 10-32, a 1/4-20 or any other UNC or UNF thread. It is a UNF thread that is on ALL the charts for fine threads.
    And it would be a really poor tap and die manufacturer that would not make that size. I would expect that most of them do make the tools for that size. McMaster alone lists at least 14 4-48 taps and one die.
    Now, 4-36 or 1/4-27 would be another thing. But that is another subject for another day. I do have the die and tap for one of those and I have encountered the other in a situation where it cost the company some real dollars.
    Quote Originally Posted by L Vanice View Post
    Larry
  16. #11
    Jun 2013
    New York
    917
    621
    488
    Piling on to what EPA says, any gunsmith would have that tap size. 4-48 is *not* uncommon.
  17. #12
    May 2009
    Canandaigua, NY, USA
    3,286
    172
    1601
    Outside of guns, I find that #4-48 is rarely used. #5-40 is another one everybody seems to ignore. IMO, very good and useful sizes, but I've never worked at a place that would let you use them.
  18. #13
    Oct 2009
    Louisville, KY, USA
    1,147
    221
    294
    You can count threads with a magnifier and a ruler, not having a thread guage shouldn't be a deal breaker. . 4-48 should have 12 threads in a 1/4 inch or six in an eighth.
  19. #14
    Feb 2008
    Illinois
    1,149
    69
    415
    Standard M3
  20. #15
    Nov 2003
    5,972
    213
    2059
    "Let you use them"? I thought shops made things according to the print, not someone's prejudice.
    I have seen many fine threads being used and also the odd diameters, like #5.
    So, if a part calls for a 4-48 thread, do you, on your own, just decide they really did not mean that and substitute a 4-40 instead? Or perhaps a metric size? M3 perhaps?
    Quote Originally Posted by Conrad Hoffman View Post
