Aluminum22
- Oct 4, 2014
- Sheboygan
Hi Guys,
Another manufacturing question. I think this is elementary. (I am still learning)
I have 5/8" Cold Rolled 1018 steel Round Rod. I have to spotface a 3/4" diameter into the side of the rod, about .18" deep and drill a hole through that of .26" diameter, centered in the spotface. Then another spotface of equal dimensions gets placed on the opposite side of the rod.
Now, considering that I am using a 14" lathe and have it fixtured to do this (cutting tools in the lathe chuck). Sorry no mill!
What are the preferred tool(s) to go about this?
I want the spotface to be flat.
I want to buy the tools off the shelf.
I understand that a center-cutting end mill will not leave a flat face.
Is there a cutter that can do drilling and spotface at the same time? Or would that be a custom cut tool?
I have at least 200 of these to do, so if I have to pay a little more for better-longer lasting tools I am OK with that.
Here is one type of spotfacing tool: Harvey Tool - Carbide Counterbores - Flat Bottom
I'm sure many of you have good suggestions to simplify the operations and speed things up.
