What type of compressor oil?
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Sep 2017
    Arizona
    62
    11
    Default What type of compressor oil?
    Blew a hose last night! Compressor was still running and with the blown hose was still keeping up to 80 PSi.
    Anyway probably a good time for an oil change! Old 10hp electric with a V-twin compressor. What kind of oil should be in this? I'm Thinking nondetergent straight 40 weight? What say you?
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,998
    3031
    1899
    I normally run non detergent 30 weight, depending on temps there 40wt might be more appropriate.
    Aug 2007
    GA
    895
    172
    I put a 7 day timer on the control on mine so I don't have to remember to turn it off nights or weekends. At least I'll probably be around if that happens...
    Sep 2017
    Arizona
    62
    11
    That's a good idea, usually shut off the breaker, but forgot on this day.
    Oct 2005
    22,016
    Quote Originally Posted by no704 View Post
    Wire to starter to the light switch.
  6. Likes Bobw liked this post
    Jan 2014
    Temecula, Ca
    3,381
    1413
    4405
    You know what I use? You're never going to guess.
    I go to Napa and I buy this stuff called, "Compressor Oil"
  8. Likes digger doug, redlee, Bobw, steve-l, pavt liked this post
  9. #7
    Feb 2005
    9,700
    16494
    11837
    Quote Originally Posted by Larry Dickman View Post
    And... Its most likely straight 30 weight with a different label and a higher price.
    I just use straight 30.. It comes in handy for so many things.
  10. Likes dalmatiangirl61 liked this post
  11. #8
    Jan 2014
    Temecula, Ca
    3,381
    1413
    4405
    Quote Originally Posted by Bobw View Post
    I'm not going to ask. LOL
  12. #9
    Sep 2005
    Oakland, CA
    3,005
    580
    956
    Best to use an oil with rust and oxidation inhibitors (R&O) added. Remember ISO viscosity grades are not the same as SAE engine oil viscosity grades. Many turbine oils have R&O additives. 30wt engine oil might be ok in a Harbor Freight compressor, but not the best choice in an industrial grade machine you care about.
  13. #10
    Mar 2012
    Geilenkirchen, Germany
    2,891
    1617
    1521
    Please restrict your advice to subjects you know about. It is obvious oil is not one of them. I know you live in the woods, but if you try really hard and use Google, you might learn something.
  14. #11
    Nov 2008
    Madera county california usa
    2,723
    21
    717
    Google the manufacturer and RTFM...
    manufacturer will specify exact oil for that unit.
    Easy...
  15. #12
    Apr 2004
    Modesto, CA USA
    8,633
    1650
    It seems to have disappeared so I will repeat my advice. I have added a pipe nipple and cap to several compressors and gear boxes. This extended the drain port far enough out it becomes easy to get a catch bucket under it and not slobber all over the base and tank.
    On my Harrison lathe the headstock drain port made a huge mess onto the vee belt. I replaced the drain plug with a ball valve and nipple with an elbow. I only insert the nipple when it is time to drain it since it sticks out so far.
    Bill D
  16. Likes Bobw liked this post
  17. #13
    Sep 2017
    Arizona
    62
    11
    Went to Ace hardware and found "Compressor Oil" no weight specified on the bottle. Already has the extended drain nipple with 90. Unknown manufacture, has a Bauldor 10Hp motor on it..
  18. #14
    Oct 2005
    22,016
    Garbage in ... Garbage out.
    You never revealed the maker of the compressor, so how doo you
    expect a definitive answer ?...
  19. #15
    Feb 2011
    2,998
    3031
    1899
    Quote Originally Posted by steve-l View Post
    The Quincy compressor that I bought used in 1989 has been running with plain jane 30wt non-detergent MOTOR oil since the day I got it, and its still running just fine. Google did not exist then, and NAPA did not carry anything called compressor oil, its really amazing how many of those old compressors from the 60's are still chugging away today with such oil abuse.
  20. Likes Bobw, WHHJR liked this post
  21. #16
    Sep 2005
    Oakland, CA
    3,005
    580
    956
    Yup! and there are those that use 30wt engine oil for way lube. Just remembered- its time to change the oil in the compressor!
  22. #17
    Apr 2018
    8,137
    3987
    Quote Originally Posted by Dan from Oakland View Post
    I guess any oil is better than no oil
  23. Likes Bobw liked this post
  24. #18
    Sep 2005
    Oakland, CA
    3,005
    580
    956
    Cool
    How about TrimSol for lube?
  25. #19
    Jan 2014
    Temecula, Ca
    3,381
    1413
    4405
    mixed 50/50 with Analeze
  26. #20
    Jun 2013
    New York
    917
    621
    488
    That's what 90WT is for, ya sick freak.
  27. Likes Rudd liked this post
