what type of electrical wire holds up best to repetitive bending
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Sep 2002
    Salinas, CA USA
    4,221
    282
    255
    Default what type of electrical wire holds up best to repetitive bending
    I am looking for some 18 ga. wire for an application where the wire will see a lot of flex. Two wires will run from an entry door into the jamb, and there will be 1/16-3/32" clearance when the door is closed.
    Oct 2005
    18,944
    I would look at the security supply companies.
    I see an "electric strike" mounted on some doors, and there is a small
    metal armored cable sending current to the door.
    No need to re-engineer the job, it's already been figured out for you
    (and probably meets all codes too)
    4612 Power Transfer Device
    Nov 2004
    Webster Groves, MO
    7,712
    1978
    3692
    In general the finest stranding will have the best life. The mechanism is that bending the wire below the yield point will have the least fatigue. The thicker the wire, the less deflection will reach that point. If you can do it, aligne the wire with the hinge line so that the cable is only twisted rather than bent. Look at the door cable on a car with power leads to the electric windows and electric locks. These cables must stand hundreds of thousands of flexes.
    Bill
  4. Likes sfriedberg, paulz, billzweig, JST, Joe Rogers liked this post
    Mar 2011
    Geneva Illinois USA
    6,467
    2844
    2555
    Tell us more about the application. Voltage requirements, length between points of attachment, current requirements, degree of flexing. How far must the door be allowed to swing, 90*, 170*? When the door is opened, the distance between the points of attachment will increase, so when the door is closed, the wire will need to have a place to go.
    Tom
    Mar 2011
    Denver, CO USA
    10,214
    58
    5698
    Quote Originally Posted by rimcanyon View Post
    No room for a festoon then.
    Current/voltage/bandwidth?
    Access to the sills/stiles?
    Why not a contact? Can the connection be made only open or closed?
    Nov 2008
    Madera county california usa
    2,570
    21
    660
    How many?
    USB mouse cords of industrial grade units are good.
    Lots of instrument cords that have rubber jacket combined with cotton cording or better braiding.
    Telephone patch cords can be made this way.
    Try contacting vendor like digikey and ask a human to help as many options.
    Feb 2001
    Redwood City, CA USA
    5,156
    210
    1040
    McMaster sells extra-fine-strand wire for flex applications. You can even buy just a couple feet.
  9. #8
    Mar 2011
    Kansas
    973
    116
    280
    Why not just run conductor/power transfer hinges?
  10. Likes digger doug, TDegenhart liked this post
  11. #9
    Jun 2015
    CANADA
    British Columbia
    1,191
    263
    622
    As mentioned by Bill above, the finer the strands the batter. And if the wire must bend, the bigger radius the better. Not only the strands need to fine but the insulation flexible. I found the silicon insulated wire used for RC cars models is one of the best deals for high flexibility wire. Available in 10-18 gauges
    BNTECHGO 12 Gauge Silicone Wire Ultra Flexible 1 Feet high temp 2 deg C 6V 12 AWG Silicone Wire 68 Strands of Tinned Copper Wire Stranded Wire Model Battery Cable Black and Red Each Color 5 ft: Amazon.com: Industrial & Scientific
  12. Likes Joe Rogers, grg12 liked this post
  13. #10
    Jun 2001
    St Louis
    18,589
    2099
    3285
    What Bill (9100) said.
    The best is to set it up so the wire is twisted, and not bent. This works for single wires, and it works for reasonable sized bundles of wire as well. "Reasonable" means the bundle diameter is at least 15 or 20 times less than the length of the twisted section. The door etc needs to move freely, and not have the wires acting like a screen door spring.
    My experience is that bends will break long before twisted wires will. The key is, however, to not let the wire end up bending at the end of the twisted section, because it may break there.
    I am not clear about the geometry of the situation the OP has. It seems from my mental picture as if that may be much smaller than is desirable for a bending situation.
  14. Likes Joe Rogers liked this post
  15. #11
    Nov 2006
    Southern California
    1,057
    10
    124
    Quote Originally Posted by billzweig View Post
    If you can afford it, Cooner Wire makes super flexible wire and cables.
    16 gauges wire with 665 strands!
    Hookup Wire NEF
  16. #12
    Nov 2004
    Webster Groves, MO
    7,712
    1978
    3692
    Quote Originally Posted by crrmeyer View Post
    Good link. A customer had a Chevalier 20 X 36 grinder stop with a broken wire in the cable to the table. It was a critical situation because it halted production of their main product. I found a cable locally that worked but was far from ideal and will probably fail again. This discussion prompted me to look for a replacement, either from Chevalier or someone like Cooner and store it.
    Bill
  17. #13
    Feb 2015
    Ohio
    504
    133
    136
    IGUS makes the best high flex.
    https://www.igus.com/chainflex/unharnessed-cable
  18. Likes adama, neilho liked this post
  19. #14
    Jun 2015
    Colorado
    599
    1209
    253
    When the application allows I use Cicoil's high-flex line. Available from Mcmaster-Carr. Can be a bit of a pain to terminate into connectors without a backshell but excellent in continuous motion and harsh environments. If IP67 or higher is required I suggest a nice backshell design with some even nicer adhesion promoters due to the silicon. Cicoil Flat Cable - Home
  20. Likes sandiapaul liked this post
  21. #15
    Dec 2007
    Central Ohio USA
    3,983
    95
    1792
    Data point: bog standard 18 ga. stranded "hook-up" wire is used in my fridge, 'twisting' thru the center of hinge, carrying 120V about 2A power to switch ice and water dispenser solenoids. Lifespan was 12 years with average daily fridge use in a household of 3.
  22. #16
    Nov 2003
    5,532
    190
    1872
    What you want is "test lead" wire. It is both fine stranded and also has insulation that is extra flexible.
    I have already narrowed this search to 18 gauge:
    Single Conductor Cables (Hook-Up Wire) | Cables, Wires | DigiKey
    I have never seen a test lead that broke anywhere other then the point of attachment and that can be easily remedied with proper strain relief that avoids flexing at that point. A simple clamp will do. You can work with it just like any hook-up wire: solder, crimp, screw terminal, etc. It should present no termination problems.
  23. #17
    Jun 2018
    10
    Though this may be outside of the realm of how much fabrication you want to do in this project, this is just a friendly reminder that there 'is' a product made especially for such continuous flex applications: Flat ribbon cable. It's the same thing that (used to be) used is applications like laptop computers (where the screen is constantly opened and closed - just like a door). In your case with close tolerance (not a lot of space for the wire/cable), the thin ribbon cable is often a good choice. The only drawback is that it often requires a little more fabrication to devise the connection/connectors. Good luck.
  24. Likes BugRobotics liked this post
  25. #18
    Nov 2008
    2,570
    21
    660
    Cable for mobile radio microphone also.
    Get Mic for ef Johnson 5300 as the Mic is real tough cord.
  26. #19
    Dec 2004
    uk
    14,046
    4552
    6717
    Quote Originally Posted by ifixcnc View Post
    Whats nice is they sell it all by the meter too and have more flavors than than you could wish for from coax to vast multi cores and power - fibre optics. Works out cheap too because again they sell by the meter, just a happy customer who uses it for a multitude of multi core - power transmission both on moving things and in cable chains.
  27. #20
    Oct 2013
    New Jersey
    1,237
    1083
    Yep IGUS. I used to buy 230 ft long servo cable with 3 power conductors, ground and two braided shielded twisted pairs for encoders. Held up very well reeling and unreeling all day long.
