What's the best way to attack a hex hole on a slotter?
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Feb 2001
    Redwood City, CA USA
    4,990
    184
    917
    Default What's the best way to attack a hex hole on a slotter?
    Assuming I have an indexing table, what is the best way to cut an internal hexagon on a vertical slotter? Should I grind a 120° V cutter and go after the corners, a flat cutter and go after the flats full-width, or a narrower flat cutter and go after about half a flat at a time and traverse to machine the whole flat? This is to make a 1/2"-across-the-flats hex hole in Durabar about 0.7" thick starting from a 0.503" hole, with the end result being the same as I'd get shoving a standard 1/2" hex broach through the hole (but without buying and busting a 1/2" broach for lack of a press with enough headroom).
    May 2017
    FINLAND
    1,775
    496
    812
    120 degree rhombic and you don't even need to rotate your workpiece
    Jan 2007
    Norfolk, UK
    18,929
    14433
    14498
    Do the flats - it's easier on the machine and cutter,...………..and machinist 'cos you have the across flat hole to use as a witness
    Narrower cutter is also easier on the machine and gives you a bit of wriggle room IME ''funny things'' can happen with shapers n slotters
    Oh & Durabar = a doddle
    May 2002
    South Central PA
    13,608
    2269
    3526
    Quote Originally Posted by MattiJ View Post
    This, as long as you don't use a clapper on the slotter. And you can buy the tool -
    Hexagon Broaches | Internal Rotary Broaches | Slater Tools, Your Source for Rotary Broaching and Screw Machine Tools
    Hexagon (Hex) Rotary Broaches | Polygon Solutions
    Oct 2005
    15,542
    Wouldn't you drill the corners first ?
    Then proceed to drill/bore the center out ?
    Then bring in the shaper ?
    Jan 2007
    Norfolk, UK
    18,929
    14433
    14498
    On a 1/2'' AF hex?
    Mar 2005
    Kansas
    7,573
    438
    3493
    He didn't tell us about his slotter, but for a real slotter I wouldn't worry until I was pushing over 3/4 wide in pre-hard.
    Feb 2001
    4,990
    184
    917
    My slotter is an attachment that goes on an Aciera F5 mill. I would in fact worry before I was pushing a 3/4" wide cutter in pre-hard...or aluminum for that matter. ;-) I would put the slotter in the same league as the Bridgeport E head, but a little more rigid and with a lot more motor behind it.
    Thanks all for the suggestions.
    Apr 2010
    Wisconsin
    6,106
    4195
    3758
    Quote Originally Posted by Limy Sami View Post
    Normally, I'm in default agreement with you, Sami. On this one though, I don't think it really matters given the job. Gonna be a doddle, either way. Frankly, if he's the indexer I'd almost rather the 120° tool, simply for being able to clean the corners more nicely. The only reason I'd favor the flat's for the easier tool to make.
  10. Likes Limy Sami, eKretz liked this post
  11. #10
    Aug 2015
    Illinois
    1,423
    1014
    618
    I don't have the cutter but have everything else needed to rotary broach it. With the cutter I could rotary broach it faster than you can set up the slotter.
  12. #11
    Jan 2016
    New York
    239
    6
    64
    Default Broach the hole
    Quote Originally Posted by Zahnrad Kopf View Post
    There shall be better chance of success to bore a hole in the work piece and make a O1 60-62 Rc broach with an undercut pilot on the front of the broach. If you require close tolerance, make an additional finish broach .0025 larger than the first. I know you said your shop lacks a press, but a press for your use should be available at any auto parts store. Press a little at a time, remove the broach; file away the chip and press again until your through the hole.
    Comments?
    All the best,
    Roger
  13. #12
    Oct 2005
    15,542
    On a 1/2'' AF hex?
    What's the "AF" designation mean ?
    I figured, looking at snap on sockets, a 1/2" hex will have 1/16" dia. corner reliefs.
  14. #13
    Jan 2007
    Norfolk, UK
    18,929
    14433
    14498
    You having some sort of a laugh - or just taking the piss?
  15. Likes eKretz liked this post
  16. #14
    Oct 2009
    Louisville, KY, USA
    954
    214
    213
    AF means "as f¥€<" on most of the internet. As in "Just make any tool and index six times. Easy AF."
    That might be the source of the "Across the Flats" confusion.
  17. #15
    Mar 2005
    Kansas
    7,573
    438
    3493
    Not everybody comes from a country where spanners are measured AF.
  18. Likes digger doug liked this post
  19. #16
    Jan 2005
    CANADA
    Saskatchewan
    10,236
    1394
    3688
    I would just drill the corners and mill the hex, maybe a little bit of file work or could use the slotter to tickle out the remainder.
    For some applications, I'd purchase a deep hex impact socket and cut the hex end off, and press fit it into the part. But a hex socket might be a bit loose on the 1/2", however it will resist wear better than the iron itself.
  20. Likes digger doug, eKretz liked this post
  21. #17
    May 2017
    FINLAND
    1,775
    496
    812
    'Muricans are not familiar with AF stamped on the wrenches since they don't use Whitworth wrench size system
    (A Whitworth wrench is sized according to the diameter of the shank of the bolt, not the head)
    And then you have the old Whitworth and new or BSF sizes... so wrench stamped 1/2" BSW fits to 3/4" AF bolt head. Depending on bolt itself could be 1/2" or 9/16" diameter
    1/2" BSW = 9/16 BS(F) = 3/4" AF
  22. #18
    Mar 2005
    Northwest Indiana
    4,216
    845
    846
    That may be true, but taken in context of a discussion concerning dimensions Across Flats, I knew what Limy meant as soon as I read his post.
  23. #19
    Oct 2005
    15,542
    Quote Originally Posted by HuFlungDung View Post
    Quick layout shows 1/16" corners, use .250 endmill will leave .041 sliver to file off.
  24. #20
    Jan 2007
    Norfolk, UK
    18,929
    14433
    14498
    Quote Originally Posted by gbent View Post
    And the USA isn't one of those countries?
  25. Likes MattiJ liked this post
