What's the best way to attack a hex hole on a slotter? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    May 2017
    FINLAND
    1,775
    496
    812
    Quick layout shows 1/16" corners, use .250 endmill will leave .041 sliver to file off.
    typical socket would use lot larger corner radius and its placed differently:
  2. #22
    Oct 2005
    15,542
    Quote Originally Posted by MattiJ View Post
    Yabutt....The OP didn't list any corner relief as a requirement, so I use it as a loophole
    to make it easier to machine.
    Don't take this simple hex hole to extremes.
  3. #23
    Feb 2001
    Redwood City, CA USA
    4,990
    184
    917
    I did a practice piece of 6061-T6 and it worked well. The cutter was a 1/4” square Prat & Whitney cutter from eBay. I put a healthy chamfer on the leading edge, but still got slight over-cut at the mouth as you can see by the pattern left from the pre-bored hole. The method won’t win any speed contests.
  4. Likes Limy Sami liked this post
  5. #24
    Mar 2006
    jacksonville,fl.
    1,126
    952
    374
    I'd love to have a slotter.I don't but have a few common size hex broaches and a key seater which are useless for blind holes.
    However I do keep some broken center drills to make various tools out of.
    A little grinding and have a nice radius tool on one end and a broaching tool to use in the mill along with the hex block.Quick and easy.
    Attached Thumbnails Attached Thumbnails 20200113_073325.jpg   20200113_073014.jpg
  6. #25
    Sep 2005
    Oakland, CA
    2,493
    295
    672
    If you play with the front clearance angle on your tool, you can eliminate that overcut to a certain extent. Also adding some top clearance will help if its rubbing on the top.
  7. #26
    Apr 2018
    UNITED KINGDOM
    2,518
    1187
    Quote Originally Posted by Dan from Oakland View Post
    If you play with the front clearance angle on your tool ...
    But you might go blind
