Azoth
- May 10, 2019
- Houston, TX
TLDR:
Basically, the roughing inserts would usually break after 1-3 facing+turning operations until I unintentionally turned the SFPM down to 250 from 550, but the finishing insert lasted for all 144 operations (72 parts, 2 sides) at 650 SFPM. Why would such a drastic difference in velocity still produce desirable results, especially since the finish speed is even faster than the roughing speed that was breaking inserts?
More info:
I hope this isn't too much exposition for a simple question.
I just started my first machinist job. I'm running the oldest lathe in the shop right now (Daewoo Puma 10S). The blanks are heat treated 4140, ~282 BHN (and I got 32 HRC near the edge and 26 HRC at the center). The part is turned down to 3.95" OD from 4.3" and faced to 2.492" long from 3".
Originally the part I was running was programmed for Roughing with [CNMG 432, .010 Feed facing and .015 Feed turning, 550 SFPM, .050 DOC on Z and .180 DOC on X] and for Finishing with [VNMG 432, .005 Feed, 650 SFPM, .005 DOC on Z (but 2 passes to double check the critical 2.492 dimension), and .005 DOC on X.] Supposedly the program had been proved out, but the people running this part before are no longer at the company. I think the inserts are carbide, but I'm just pulling lightly used inserts from around the shop of random/unknown brands and specs. I had 1 new insert that I never used because I didn't want to break it after 1 operation.
The second most recent hire (also inexperienced) ran 38 of these parts before I took over. He said he was getting 2-3 parts per insert. The guy who set the job up for him thought .180 DOC on X was too much and reduced it to .100 and tried turning the feed/speed overrides up and down as it cut to see how it responded, but nothing came of it. They just gathered a bunch of lightly worn inserts from around the shop to run through.
I started checking the insert condition after the rough facing op and before the rough turning op to see it was broken. I would turn the spindle down to 50% to reduce the speed of the chuck while I open the door and look. I forgot to turn the spindle back up one time and noticed it was at 260 RPM mid cut (at 3.96 OD = ~250 SFPM), but it sounded fine. I then set the SFPM to 280 and was able to run the final 6 parts on the same insert without it wearing out or breaking.
I also turned the DOC back up to .180 from .100. After noticing the chatter from that, I overrode the Feed + and - 10%, mid-cut, to see which sounded better and ended up turning the feed up to .0165. Spindle load increased to 70% from <20% for this. I ran it at 70%, but I've been told by 3 other guys on 3 different occasions/jobs that I ran to watch the Spindle load (and x, y, z loads on mill) for indication of an issue and that it shouldn't be above 50-55%.
Another thing I noticed: the finish pass leaves a poor surface finish on the face from 1.07" diameter down. The lathe was ran in low gear and tops out at 840 RPM. When facing it dropped below the programmed 550 SFPM and 650 SFPM at 2.501" and 2.956" respectively because it can't go faster than 840 RPM. Before I accidentally adjusted the rough speed down to 250, I had already thought that 235.3 SFPM was where it's too slow based on the poor surface finish at that speed and lower ((840RPM × 1.07"Ø × π) ÷ 12") = 235.3 SFPM.
So I wanted to ask if there's a rule of thumb for speed choices for roughing vs finishing. I get how feedrate, tool geometry, rigidity, etc. are important for a good finish, but I don't see the connection to increasing the speed.
And, concerns that came up as I wrote all this out:
Would the difference in hardness from edge (32 HRC) to center (26 HRC) of the part be a possible reason for the poor surface finish as the cut approaches center?
Was it risky of me to run the final parts at 70% spindle load during the rough pass? (and while roughing the face, spindle load briefly rose just above 100% as the RPMs increased to it's max of 840)
Sorry, for going off topic on my first post. Appreciate any comments.
More info:
