Where can I find a 1 7/32" x 8TPI lathe backplate?
Results 1 to 12 of 12
    Mar 2021
    Arizona
    Default Where can I find a 1 7/32" x 8TPI lathe backplate?
    I have a lathe with a threaded spindle that appears to be 1 7/32" x 8TPI. I can't find any back plate with that thread. Where can I buy one?
    Jun 2004
    632
    519
    117
    some more info would be nice like who made the lathe that you have
  3. Likes CORONA VIRUS liked this post
    Aug 2015
    Illinois
    1,681
    1288
    730
    I suspect you will have to start with a backplate casting and machine it yourself.
    Feb 2020
    Alabama
    366
    151
    104
    Make one. .
    Feb 2020
    Alabama
    366
    151
    104
    Quote Originally Posted by 1yesca View Post
    Don't tell me you never got a blueprint with half of the dimensions missing. You don't do aerospace, do you? You know how all those planes keep falling from the sky?
    Feb 2006
    Indiana
    13,881
    797
    4642
    Quote Originally Posted by thechickencow View Post
    There are more details you could supply in order to get a more complete answer. The best answer to the question as asked is that you cannot buy one. I will take a wild guess that you cannot make one yourself.
    But you could have one custom made, which is a time-consuming job that should be quite expensive if done right so that it fits your machine. The maker would want your lathe spindle to measure and use as a gage. You would have to have a chuck in hand or at least in mind to allow the diameter of the plate to be known, along with the thickness and where the holes will be drilled.
    And there is always the possibility that the spindle has a metric thread.
    Larry
    Jun 2004
    632
    519
    117
    Quote Originally Posted by CORONA VIRUS View Post
    i hear you but we at this point don't know for a fact that his info is correct and by knowing who made the machine and maybe a model it may clear some things up . yes we all reinvent the wheel at times . time . and that's just it . time . what is yours worth to you . any time you can buy something off the shelf most of the time your ahead of the game but sometimes you must reinvent the wheel
  9. #8
    May 2005
    AZ
    2,508
    250
    857
    I'll step out on a limb here, and speculate that the thread is quite possibly 1-1/4 x 8, rather than 1-7/32 x 8. I would check the spindle thread with thread wires to confirm its actual pitch diameter, then decide what you are looking for. As others have noted, some additional info regarding make and model of the lathe might help clear up some questions.
  10. Likes Rudd, 1yesca, 4GSR, MotoX liked this post
  11. #9
    Oct 2009
    Louisville, KY, USA
    1,127
    221
    285
    I came here to say the same thing specfab said. 1-1/4"-8 is a common lathe spindle thread and the actual OD of a threaded part should be less than the nominal dimension. the difference between 1-1/4" and 1-7/32" OD is .016" off the crest of the thread.
  12. #10
    Nov 2004
    WI
    4,824
    597
    1196
    Let me guess... The OP got a lathe without a chuck, or back plate.
    That is a problem to make a new back plate without a way to hold it.
  13. #11
    Jul 2004
    Houston, TX USA
    32,120
    How to measure it. The wires for 8 pitch will be some specific size - look it up
  14. #12
    Apr 2011
    Nebraska
    1,433
    2386
    481
    Quote Originally Posted by fciron View Post
    A South Bend 11" uses a 1-5/8"-8 spindle thread and I think there is another, more common lathe that shares that size (can't think of brand atm). While not as common as the 1-1/4"-8 it is still a possibility. It sure would help if the OP would give a few more hints as to the machine and size, etc.
    FWIW
    -Ron
