Mike C.
- Nov 25, 2004
- Birmingham, AL
Just out of sheer luck scored an older Heidenhain DRO with two perfectly sized scales for my VN2G bridge mill for no more than beer money. The sealing lips on the encoders/scales are gone, rotten, dessicated, totally non-existent. I have done a little searching and already found somebody that tried to get them from Heidenhain and found them discontinued (of course, just my luck). I dug into my past and even tried an old Unger squeegee blade from my window washing years. It's about a 1/8" bead and the hole at the bottom of the encoder seal slot is about 3/32... just enough that it won't fit. I can't help but think that I have seen some kind of similar thing, maybe automotive or something that could work. Any ideas?
Also, the table scale will be mounted with the slot facing downwards and the head sticking upward into the housing slot (only way it will fit), not much fear of chips or coolant in there. The cross rail scale and head will be on the back side of the rail, and on top of the rail, 2 ft from any chips or coolant and protected by the rail (only runs coolmist, anyway), so these will really be not much more than dust seals.
