Why can't I get my grease gun to release?
Results 1 to 18 of 18
    Jan 2009
    Panama City Beach, Florida
    119
    21
    Default Why can't I get my grease gun to release?
    Is there some trick to getting a grease gun to let go of the zerk? On all my chucks and collet closers that have recessed grease fittings, I have to unscrew the head from the gun to get it off the fitting. There has to be a better way, no?
    Regards, Ray
    Oct 2005
    22,542
    Ussually, the coupler stays locked because the pressure is still up
    on whatever you just filled. That's the beauty of the Zerk system,
    more back pressure actuates the coupler lock harder.
    However, does this only happen in the recessed zerks ?
    Sep 2010
    moscow,ohio
    6,531
    675
    2267
  4. Likes Zahnrad Kopf, drom68 liked this post
    Oct 2005
    22,542
    Quote Originally Posted by iwananew10K View Post
    I have one of those (it was a gift) yet to install it on the grease gun because
    the diameter of the coupler is too large for the recessed fitting I have.
    Aug 2008
    Californeeeah
    1,581
    60
    354
    I can see how that happens. Most of the time you have to tilt the coupler to crack the pressure. You can't tilt it enough with a recessed coupler. You may have to resort to a needle. They're made for close quarters.
    Jan 2009
    119
    21
    Those lock on couplings are 5/8 OD and won't fit into my recesses.
    Digger, Regarding the pressure, it never drops off enough to release the fitting.
    I have done all buy leave it on overnight!
    Regards, Ray
    Jul 2006
    Arizona
    4,731
    18887
    4580
    Disassemble and remove the small check ball from the grease gun chuck. Removing it will not allow the grease gun to build up back pressure. You have to make sure to get the grease chuck on square to the grease zerk while pumping in the grease otherwise it makes a mess.
  9. #8
    Oct 2005
    22,542
    Quote Originally Posted by rbrandes View Post
    Regards, Ray
    Maybe make up a short adapter (or buy one) that has the smaller 3 jaw coupler (for in the recess)
    a short piece of 1/8" pipe, and then a normal zerk.
    Pop off the grease gun from the adapter (leaving the adapter locked onto your troublesome fitting)
    Then remove the adapter. You could also remove the check ball from the adapters Zerk, to dump
    the pressure when you uncouple it.
    Not removing the check ball in the coupler, then you have to press very hard to keep them engaged,
    and with this fitting holding back pressure, it sounds like it will be hard to push in that hard.
    EDIT:
    Or, this:
    Univer-co
  10. Likes wheels17, Philabuster, jh35 liked this post
  11. #9
    Jan 2007
    Norfolk, UK
    21,386
    16754
    17470
    Have you tried operating the chucks and closers a few times, .........movement of the greased joints moves the grease about and kills the back pressure.
    Admittedly I've never tried it on chucks etc, but it's worked on everything else I've greased.
  12. Likes digger doug, JLarsson liked this post
  13. #10
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,250
    1075
    803
    IME enough residual pressure to make removing the coupler difficult, usually means the fitting is plugged and grease did not get in anyway. Time to take it apart and make sure the grease gets through OTOH, last time this happened to me I jacked the truck up to take the load off the spring shackle and the grease went right through.
  14. #11
    Jul 2004
    Southeast Michigan
    6,940
    276
    1763
    Damnit...I was hoping this was about anorgasmia. I mean, we had the amazingly popular viagra thread.
  15. #12
    Oct 2012
    Virginia
    10,264
    5843
    4639
    Quote Originally Posted by snowman View Post
    Zerkus captivus, rather. AKA the recessed fitting designer had dog-shagging on his mind...
  16. #13
    Sep 2010
    moscow,ohio
    6,531
    675
    2267
    nah, if it were dogs shagging you could just toss some cold water on em.
  17. #14
    Oct 2005
    22,542
    Quote Originally Posted by Monarchist View Post
    I believe this is the proper term eh ?:
    Penis captivus - Wikipedia
    You all still thinking of the "Wood box with the needle & the bottle" ?
  18. #15
    Jul 2004
    Southeast Michigan
    6,940
    276
    1763
    lol...no, i's got no problem getting my grease gun in the proper position, it's all about the injection of the grease. Too many SSRI's and too much stress/anxiety.
  19. #16
    Oct 2005
    22,542
    But if only you would have read the OP's problem, it was
    AFTER injection, he can't get it to release.
  20. #17
    Jul 2007
    Brookfield, WI
    692
    964
    618
    Help me out here, Doug. Is that a reference to a Catherine Deneuve movie called "Belle du Jour"?
  21. #18
    Oct 2005
    22,542
    Quote Originally Posted by Ron Hofer View Post
    Read thru Milacrons "I love Viagra and Tinder" post (scroll down to line 94), all will
    be revealed....
