Why do indexable insert holders use a shim?
Results 1 to 16 of 16
    Oct 2016
    Wisconsin
    73
    12
    19
    Default Why do indexable insert holders use a shim?
    Why do indexable insert tool holders have a shim, what is it made of, etc?
    I will post an even dumber question as soon as I think of one.
    Feb 2005
    9,541
    15978
    11570
    You mean a seat? A carbide seat?
    Its so when you have an *OOPS*, you rotate or replace a $10 carbide seat instead of
    spending $75 on a new tool holder..
    Very nice feature on face mills.. $50 for new seats instead of $300 for a new cutter body.
    Jan 2005
    CANADA
    Saskatchewan
    10,282
    1407
    3739
    Even without an OOPS, the vibration of the insert during cutting will wear into a steel seat. When using a double sided negative insert with chip breaker geometry, there isn't a lot of surface area in contact with the seat, so a lot of small pressure points exist, and these can etch into the steel. I've got a few well used boring bars that have gotten this way, due to the fact that there isn't room for a carbide seat.
    Jun 2013
    Oregon
    1,729
    618
    1042
    The carbide seat used under a lay down type of threading insert on a lathe is actually tapered. The taper is different according to the diameter of the part you are threading.
  5. Likes Jashley73 liked this post
    Apr 2017
    ZIMBABWE
    128
    13
    35
    I have always wondered why...but never gave it much thought.
    Thank you
    Dec 2008
    New York
    10,398
    2711
    Quote Originally Posted by rabtrfld View Post
    amazing is the cost for screw and shim is often over $20.
    Nov 2004
    Birmingham, AL
    13,327
    6617
    2620
    What Hu said. The carbide seat is to prevent the insert digging itself into the floor of the holder.
  9. #8
    May 2011
    Sandy Hook, MB Canada
    890
    179
    Quote Originally Posted by Gobo View Post
    Hello Gobo
    Might I add that if you want to cut external/internal left hand threads & only have an external/internal right hand tool holder & insert, you can install a negative angle anvil to cut those left hand threads.
    Last edited by Ciszewski; 11-25-2017 at 02:09 AM. Reason: Typo: Forgot the "n" in an.
  10. #9
    Jan 2007
    Flushing/Flint, Michigan
    9,890
    549
    8142
    Crash protection being the number one reason by far.
    Break a tip and that shim seat will still cut a little, hopefully you notice soon enough as it cuts very badly.
    Brinelling of the floor # 2.
    Both talked about above but there is a third reason.
    When using a negative insert your unused sharp cutting edge is down.
    You can't make a pocket with absolute sharp corners so without a shim seat you have to add the cost of undercutting the floor/wall intersection to prevent chipping the downside of the insert.
    This undercut is sometimes called a "dirt relief" but it's real purpose is that no endmill makes zero corners.
    Shim seats have a 45 on their bottom so you do not need to add this operation that is done with very short lived and fragile tooling.
    ( and yes shim seats are low cost C-2 carbide with a top and bottom grind. Expensive only because of the volume they are bought in, in quantity they are much cheaper)
    Threading shim seats are a different story being one sided tools and this relates to helix angle and maintaining the needed heel clearance which is why they are tapered.
    Somewhat weird the terminology or correctness of "shim", "seat" or "carbide seat". Not really a shim or maybe it is.
    Anyhoo, if you make toolholders you will know what the customer is talking about instantly and that is all that matters.
    For a user.... they make your holders last longer and that is what really matters.
    Bob
  11. Likes Bobw, Mike C., digger doug liked this post
  12. #10
    Oct 2016
    Wisconsin
    73
    12
    19
    Glad I asked! I bet there's people on here write Wikipedia articles and I hope they do cuz you don't find this stuff anywhere else.
  13. #11
    Nov 2020
    Ohio
    Rabtrfld and Bob,
    The number one reason for a Shim in the pocket of a lay down thread bar is to control the Helix of the thread. The other reasons listed are reasonable but have nothing to do with the actual reason the shim/seat is in the pocket. The reason smaller bars do not have a shim/seat is because the smaller the thread diameter the less of an issue the Helix becomes.
    Sr. Apps. Eng. Kennametal
  14. #12
    Jan 2007
    Norfolk, UK
    21,016
    16443
    16937
    Quote Originally Posted by Sr_Applications View Post
    Rabtrfld and Bob,
    Should that statement not be the finer the pitch the helix is less of an issue, .........cos it sure is on sub 1/2'' Acme and the like.
  15. Likes eKretz, gregormarwick liked this post
  16. #13
    Jan 2007
    wales.uk
    1,517
    295
    316
    I thought it was so you could loose the bloody thing in the chip pan making you clean it out, sort of machine hygiene accessory thing, like the little torx screw,
    Ok jokingly, who hasn’t lost one
    Mark
  17. Likes Mark Rand, Limy Sami, mjk liked this post
  18. #14
    Mar 2005
    Indiana
    5,700
    1891
    1844
    Quote Originally Posted by Limy Sami View Post
    Absolutely. That guy wasn't thinking very clearly when he wrote what he did. For a given pitch, the larger the diameter the less the helix angle. For a given diameter, the greater the pitch the more the helix angle.
  19. Likes Limy Sami liked this post
  20. #15
    Jul 2006
    Cumberland, Maine
    515
    84
    127
    Quote Originally Posted by eKretz View Post
    The Kennametal engineer’s choice of words was poor. The angle of the insert in no way “controls” the helix angle of the thread. The helix angle is “controlled” by the parameters of the thread itself - pitch and thread diameter.
    The insert just goes along for the ride.
  21. #16
    Jan 2007
    9,890
    549
    8142
    Maybe we are mixing lay down threaders and a CNMG pin lock toolholder?
    Shim seats holders were around long before this type threading tool came to market.
    Where is the angled shim seat on a top-notch threading tool?
    Who made the lay down threader popular as the go to we all know? Hint, starts whit a C and on 8 mile in Detroit.
    Standard pin lock/ top clamp holders have a flat shim seat and guess who started that now standard design.
    I would be remiss If I did not do a big ass welcome to Sr_Applications to the board.
    Any input is welcome, you may get hit a bit but do not take it personal when some talk back.
    I am sure you know things we do not.
    Bob
  22. Likes digger doug, eKretz liked this post
