Finegrain
- Sep 6, 2007
- Seattle, Washington
1018 steel
1" thick
.7504" thru bore
Rough it out to .748" with an endmill
Brother Speedio S700X1
Stanny micron boring head
16mm x 60mm bar
TPGH09020L TN60 insert (Kyocera cermet)
2,000 RPM
.0015 IPR
Flood coolant
I get good results for 4 or 5 parts, then I have to start bringing the cutter out a couple tenths between parts, then after 7 or 8 parts the surface finish suffers and I have to rotate the insert.
Why so poor tool life?
Thanks, and regards.
Mike
1" thick
.7504" thru bore
16mm x 60mm bar
2,000 RPM
.0015 IPR
Flood coolant
Mike
