Why filler on cast iron machines?
Results 1 to 12 of 12
    Jan 2015
    Arizona
    239
    15
    Default Why filler on cast iron machines?
    Why is there so much filler on cast iron machines? The filler that I'm referring to is the stuff used to smooth out the roughness on castings.
    Feb 2002
    Peralta, NM USA
    5,779
    52
    513
    Even if you managed to grind everything off you'd have to have some filler for the divots. So there's some happy place where the worst of the cast is ground down (sprues, risers, etc.) and filler is use to smooth the rest.
    Jun 2015
    CANADA
    British Columbia
    1,191
    263
    621
    The filler is to compensate for rough casting surface. In the 19th and early 20th century many castings were polished smooth like a mirror. This obviously is too expensive today. Still, some of the filler today is way too thick and of poor quality.
    Jan 2005
    Victoria, Texas, USA
    4,219
    2488
    1091
    Extra coat of Rusteloum primer will smooth out most surface imperfections.
    Feb 2011
    2,428
    1916
    1072
    Smooth surfaces are easier to clean and they tend to look nicer on new equipment.
    Virginia
    30,324
    7561
    9484
    Quote Originally Posted by beeser View Post
    It's used to smooth out the roughness on castings.
    Next question?
    Virginia
    30,324
    7561
    9484
    Quote Originally Posted by 4GSR View Post
    Meahhh.. some castings, yah might wanna cut it 50-50 with ping-pong balls...
  8. Likes adama liked this post
  9. #8
    Jul 2004
    Houston, TX USA
    30,693
    The main reason is that castings are never perfect assuming unmachined surfaces. There are both external and INTERNAL flaws. Dig the blow hole in this Greaves Clusman cabinet leg.
    Would you have the boys just paint over such things?
  10. #9
    Aug 2011
    Oregon
    2,570
    588
    782
    Is there a "before" photo?
  11. #10
    Jul 2004
    Houston, TX USA
    30,693
    Quote Originally Posted by partsproduction View Post
    Sure, but not relating to blow hole which was opened during machining to effect repair of busted up cabinet leg
  12. Likes partsproduction liked this post
  13. #11
    Aug 2011
    Oregon
    2,570
    588
    782
    John my hat's off to you, that looks like a heck of a project.
    My brother had a GK lathe, big old beast. One gear internally was broken before he got it so he worked around a few speeds. Finally he sold it and the new owner enrolled in shop class to make a replacement gear I was told. I wonder how far he went to duplicate it as original.
  14. #12
    Dec 2008
    New York
    10,305
    2668
    when cast iron extra hot it tends to penetrate more the sand mold and leave a rough surface. common to use a thick epoxy type paint to smooth it.
