Why are spotting drills so expensive?
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Sep 2010
    Oklahoma City, OK
    4,845
    856
    2015
    Default Why are spotting drills so expensive?
    I don't understand why these things are so pricey.
    At Maritool a #3 center drill is $5.07, but a 1/4" spotting drill starts at $16.12.
    What am I missing?
    May 2010
    Cambridge, MA
    1,652
    71
    946
    Spotting drill industry is controlled by the Illuminati. Center drill industry is not.
    Feb 2006
    Indiana
    13,149
    725
    4079
    Maybe just low demand = low manufacturing volume = high cost.
    Larry
  4. Likes digger doug liked this post
    Sep 2010
    Oklahoma City, OK
    4,845
    856
    2015
    Quote Originally Posted by jscpm View Post
    It's that damn George Bush! lol
    Quote Originally Posted by L Vanice View Post
    Larry
    I suspect this is the case.
    Feb 2010
    ch
    2,466
    212
    320
    could someone post the tipp of a spotting drill, please? (i just bought some and i dont like them.)
    Sep 2004
    Sonora , Calif
    590
    121
    126
    Enco has 1/4 Keo spotting drill for $7.01 and Enco brand is cheaper .
    Jim
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,150
    450
    1077
    Many spot drills are solid carbide (extra rigidity in the base material) as opposed to HSS center drills (supposing there are solid carbide center drills but never seen these up close & in person).
    This drives up the price.
    IMO its worth the extra for solid carbide, as it won't wander when you are trying to spot-up a broken bolt, slightly inclined surface, etc. I think the tip is a lot tougher than a center drill, that is, as long as you don't drop it, free-fall style, from the chuck!
  9. #8
    Mar 2012
    Houston
    75
    9
    28
    There are carbide center drill which I have used but did not really have good luck with them. I prefer a HSS center drill or even a HSS spotting drill. One problem that I have is the angle of spotting drill I use is 45 Deg. and drills are not, so sometimes it will notch the cutting edge on drill. Im not sure what price range is on the spotting drills we get from MSC.
  10. #9
    Dec 2003
    13,150
    450
    1077
    Quote Originally Posted by TXMachinist View Post
    Best info I have (and what I use) are 120deg included spot drills which interact nicely with 118deg HSS drill bits and provide a nicely fitted "temporary locating cone" to get the first drill bit on location. I would think the 90deg would provide some of these benefits but could wander if one drill edge before the other "digs in" a bit on the sharp spot hole edge.
  11. Likes aerodark, jdtoolmaker, Archer120x liked this post
  12. #10
    Feb 2008
    Utah
    2,889
    In an aerospace shop (I assume many shops like that one) I once worked at, they used 120° Spade drills to spot and countersink tapped holes. These holes had countersink diameter tolerance of Ø .010 total. STI tapped holes were common, and true position of .010 were standard.
    http://www.google.com/imgres?hl=en&s...9,r:0,s:0,i:75
    You won't be crying about the prices you pay now when you see what these list at!
  13. #11
    Sep 2009
    Mooresville, NC
    419
    75
    114
    I was taught the spot should be more obtuse than the drill so the web of the drill can find center first.
  14. #12
    Feb 2005
    9,215
    14839
    11028
    I can't figure out why the things are as expensive as they are, I also can't figure out why they all aren't double enders. It is the ultimate tool
    that lends itself to being a double ender. Center drills are double ended, not spotters. Sure would be nice if they ground a spot drill on
    the back end of endmills. I'd pay a few more dollars for that.
    I've pretty much given up on spot drills, especially carbide ones, I've got piles of them here that are all chipped up. I've got quite a few HSS
    spotters too, and they seem to last and last. I used one 5/8 for like 3 years until an oops moment.
    I don't get the geometry of them either, really not very good.
    Lately, I haven't been spotting anything, either just slam the drill in, or I've been piloting with an 1/8" carbide drill(or 3/32), that works great when
    drilling something that can't take a lot of down pressure.
  15. #13
    Sep 2010
    nj usa
    108
    10
    I checked a .375 spotting tool vs a .375 screw macine drill, spot about 31.00 drill about 16.00. Seems to me it should be cheaper to grind the spotting tool. Both tools are cobalt and the same oal.. I don't get it.
  16. #14
    Sep 2010
    Oklahoma City, OK
    4,845
    856
    2015
    Quote Originally Posted by art421 View Post
    Exactly. It makes no sense.
  17. #15
    Nov 2007
    Hamilton, Ontario
    1,125
    816
    428
    I had a job that I posted about here that I had broken a number of 1/4" drills and an end mill on the previous time I ran it. Following the suggestions here I got a price for 1/4" spotting drills of over $30 each, I couldn't believe how expensive they were. I ended up buying 4 screw machine bits for about $6 each and drilled all the holes with one or two bits. I was lucky and didn't break any but I did take the corners off the bit, which I can sharpen later or I can afford to throw away a dull $6 drill bit.
  18. #16
    Jan 2012
    Ohio, USA
    361
    381
    134
    Not worried about the price as an operator but all I always use a 120 degree solid carbide garr spot drill for an hss drill and get about. 0005 -. 0015 runout depending on the drills shape. And a 130 degree when using a titex or nachi 135 degree drill and hold. 001 with a same drill for a whole job up to 100 parts. Can't do that with a center drill.
    Also made up my own little formula for spot drill depths. Spot drill diameter /3 then take 75 percent of that number. Don't know anything behind why but it works real well for me.
  19. #17
    Sep 2004
    Sonora , Calif
    590
    121
    126
    In new Enco hot deals flyer that I got today ,they have Melin solid carbide 1/4 dia 2 flute end mills that can be used for spotting for $12.99 to $16.99 depending upon point angle. May 4th.
    Jim
  20. #18
    Sep 2008
    Houston TX USA
    50
    12
    5
    Quote Originally Posted by Lyk31337 View Post
    Doesn't that work simplify down to Spot drill diameter/4 ?
  21. #19
    Jan 2012
    Ohio, USA
    361
    381
    134
    Quote Originally Posted by Sleazey View Post
    Sure would but meant 70%
  22. #20
    Sep 2010
    Oklahoma City, OK
    4,845
    856
    2015
