geardoc
Cast Iron
- Aug 8, 2012
I went to an absolute auction of a company that had done injection molding. In their tool room they had 2 Acers, 2 Acras, and 2 Titans. This was in the Macon GA area.
All of the machines followed the basic Bridgeport Series 1 Vari-Speed Copy.
They all weighed between 2500-3000lb.
All had the handle and knob for quill speed REMOVED- there was still the little tip to add it back but no way to use quill speed. Everyone at the facility was laid off except for a guy from production, he started to say, "Well, they ran." However all machines had surface rust on the ways and they had some surface rust on the tables, all had idiot marks on the tables.
The guy from RBA silenced the guy from production and said all machines are as is, and had not been tested and there was no way to test them. Not quite true, as the machines were locked out, but still connected, power was still up in the plant(CNC's were being demo'd- including one they crashed).
Curiously there were two mills made by Acer that were brand new, in the corner- marked "LEASE- NOT UP FOR BID." The handle had not been removed for the quill feed speed on those. There were also several JET lathes of tool room size 14"-18" swing also marked "LEASE- NOT UP FOR BID". They were in immaculate condition.
The lathes they were auctioning ranged from an old Logan to Korean South Bend, all beat except for the JET lathes.
I'm just wondering in a tool room that specialized in reworks, is there a reason they'd have removed the ability to use and change auto quill feed ?
THANK YOU !
THANK YOU !
