The tube size is 6.5" ID .250" wall 20" long. The job is take a clean up cut off the OD and ID so they run true with each other and split it down the center lengthwise. This is easier said than done on a tube this size. The halves do not need to mate back together to form a round tube. They are getting clamped back together over two 6.5" Dia rollers to straddle the distance between them. This is just a setup tool. Its not going to spin or move in anyway. They will take a measurement and remove them. My first thought was use a piece of honed tubing. The ID is already done. Take a clean up cut off the OD and saw it in half. I told them it was going to spring. The only way I could see keeping it straight is to take 2 tubes and saw them just over half. Mill the split line. Clamp them back together somehow to turn and bore it. The length makes doing it this way a challenge though. Also it would be very expensive to do it this way vs sawing it in half and its done. I didn't know if seamless tubing would spring like welded tubing does.
Aaron
Aaron
