basalt
- Jun 22, 2013
- Vancouver BC Canada
I tried to research this but could not find a good answer. Do solid thread dies have a relief behind the cutting edge? If so wouldn't turning the die around negate this relief and possibly break the teeth?
Almost all HSS Ground Thread dies - both split and solid, are form relieved ground as per your pic, and yes running them backwards probably will damage them, and WILL produce poor ill fitting threads.
You don't say why you want to thread that close to a shoulder, but it's considered bad engineering practice, - it creates stress points etc etc,.......''good practice'' says 1 1/2 thread pitches minimum from a shoulder, with an under cut if the female has to abut the shoulder.
If you have to thread up to the shoulder either find a die with no lead in, or grind the face of a fie to remove the lead, .......if threading by hand etc you will need to go as far as you can with a die with lead, then do the last bit with a zero lead die.
Whereas Cut Thread dies have no form relief, so up to a point can be turned over, ....but Cut Thread dies are usually cheaper and considered inferior, for they are basically a tapped hole in high carbon steel that is then heat treated, with possible distortion etc etc from HT and having no thread relief can make threading on some material VERY hard work and often at best ''so so'' work.
Notice
