wiring crompton parkinson motor
Results 1 to 4 of 4
    Oct 2016
    IRELAND
    9
    12
    Default wiring crompton parkinson motor
    any body wire a Crompton Parkinson ph1 240v motor ?
    this motor had a 7 core wire for reversing the motor
    it also has two extra wires coming out of the motor to the motor terminal box
    it has a capacitor start
    how do you connect for single direction running
    Nov 2004
    Webster Groves, MO
    7,742
    1992
    3717
    The information should be on the inside of the cover plate. I suggest you post this in the transformers, phase converters and VFD forum.
  3. Likes Index man liked this post
    Jun 2015
    UNITED KINGDOM
    35
    5
    14
    Is there a data plate on the motor? there are a different number of poles in an induction motor according to intended running speed. 2850 RPM @ 50hz would be a 2 pole motor. If it's 1425 RPM it would be a 4 pole motor.
    Changing the pole connections reverses the motor. When I've set up single phase motors to reverse it's only needed four wires out to a 2 pole changeover switch rather than seven.
  5. Likes Index man liked this post
  6. #4
    Oct 2016
    IRELAND
    9
    12
    Thanks for the replies
    Wish there was information on the cover plate
    The two extra wires that come out of the motor
    Are What I do not understand
    Poles marked A and Z go to the capacitor
    Might move as suggested to a different forum
