Terry Keeley
Titanium
- Oct 18, 2005
- Toronto, Canada eh!
Searching around I thought they were all integral on the UPA2 but I see one for sale that looks like it has a screw on Moore adapter.
Any ideas?
Any ideas?
Yep!
Bog standard MT2 shank inside a Moore adapter. From the one pic showing the cross hole, they did not go to the trouble of screwing a removable tang on to the taper shank of the UPA2, so some careful wedge work may be required to separate them.
I got a pretty good buy on a UPA2 out of England, that someone had slid a taper sleeve of some sort on to, and then ground it to a straight shank. It wasn't done very pretty, and there was some slight rust showing, but all in, nothing that affected it's function.
So the Moore adapter is just pressed onto the MT2 shank? And you "should" just have to tap a drill drift into the slot to separate them?
You should, IF there was a removable tang installed in the drawbar threads (they are out there).
But if there was a tang installed, it would be visible in the hole, thus, it is going to take a little jiggery pokery with some other wedges to remove the adapter from the original shank of the UPA2. The easy way is between the base of the Moore adapter and the root of the MT2 taper of the UPA2.
Think along the lines of a matched pair of low angle wedges along the lines of those used to separate some Jacobs Chucks from their arbors, essentially U shaped cuts in a sloped surface that you can squeeze together with a clamp or vise (maybe a vise, if she has great thighs!) :P
Really, something you should be able to bang out freehand on a mill in a few minutes.
I think that is a plain old normal length MT2, but now having a better look at it, the slot looks like it is for retaining rather than ejecting, so you may need the wedges that trev described to separate it. You'd have to see exactly how the slots line up to each other to say for sure, but from that picture it looks like trying to use a drift would only pull the boring head in tighter.
I'm glad someone else is seeing that too, I looked at it long and hard and figured a drift wouldn't do it.
I've asked the seller if he can remove the adapter, I'd need to see what's underneath before I consider it...
i often succeed in removing a taper without tang by inserting a bearing ball (or something else)and using a drift as usual.
I tried zooming and could still get only a HINT as to it being an adaptor "maybe". Flats for a wrench hint at removable?
As to the tapered portion, no adapter assured. It could as easily be all of a piece and you are looing at the locking drift azure, hor-bore spindle style, and put there for the same reason.
Might be less of a risk to just move-on to another less mysterious Wallbanger, Narex, Gamet?
Or - if yah can FIND one - even a Chandler-Duplex?
I got mine! Straight shank. And 'native' NMTB 40 collets to match.
The wrench flats are for the outer Moore adapter - those screw in. Pretty safe bet it's an MT2 inside there.
Here's one that has a straight shank, WTF?
Notice
