I Know this subject had been already covered.
The reason i am opening a new thread is because i just bought off ebay a upa3 2140002011 with morse 4 deckel shank (mo4 x s20 x 2) and i am comfused if it has an integrated shank or not.
Seller said that the shank is interchangable but from my google search and over the practical machinist similar threads i only read that this is an old type upa3 that is one piece with the shank .
I dont see any hole in the upper side of the shank so there is no hex bolt to loosen the shank like on the newer versions .
The reason i am not sure is that i can see a taper between the shank and the main body of the boring head .
Is there any posibility to remove the shank with wedges like we do on drill chuck with jacobs taper ?Do you know if wollhaupter ever made such a removable shank ?
Thanks for your help in advance.
