A straight side single flute was reground into a custom dovetail cutter and worked fine in one each of C464 Naval Brass and tough cast iron."
Nice work, John. Gives me some ideas regarding the gage blocks. Do you have a good set and a "shop" set, or is this standard practice? I guess I've only thought of them as inspection devices, but have no training or examples.
Thinking a little farther along, i guess on a jigborer it would be practical. On a mill, the machine can't utilize any excess precision, so a couple adjustable parallels set to a mic would be just as good?
Regarding the OP, I have used formed router bits in a mill, and ocasionally cut out sheet aluminum up to about 1/4" with either router bits or a milling bit in a hand held router, to wooden guides or forms. Have also used up to 1/2" round over with a piloted bit and guide back up (for when the pilot bearing dies
) in a hand held router to bullnose lenghts of naval brass and 6061 Al for architectural applications. Not real fun with the noise, vibration, stress, and sharp chips, but pretty efficient.
smt
