Working with molybdenum
Results 1 to 19 of 19
    Oct 2017
    537
    138
    144
    Default Working with molybdenum
    My parents have a wood stove that they light with one of those waxy fire bricks every cold morning. It's always a bit of a balancing act trying to get one corner of the starter up off of the base to have a surface to light with a match.
    I was thinking that for a late father's day gift I would try and make a small stand out of a refractory metal that could hold these bricks while exposing the lower surface for easy lighting.
    I understand that there are much easier ways to do this, and honestly it's such a minor problem we've never bothered trying to solve it, but I have an interest in these types of metals and it would be a neat gift regardless.
    So my question is, how difficult is molybdenum to work with? I would likely be using 0.047" thick pure Mo sheet and would like to form it into a sort of box if possible. I would be using a 1/4" radius punch and probably 7/8" V die, with urethane die film, to a 135 degree obtuse angle. I am having a hard time finding a description of the brittleness of this metal.
    Also, is this possible to plasma cut or shear, or what? I will be ordering a square of material large enough to do a few tests, but I would like to have some idea of what I am getting into if anybody has worked with this stuff.
    Jul 2006
    Hillsboro, New Hampshire
    7,232
    1700
    5003
    According to this doc: http://www.molybdenum.com/wp-content...-Machining.pdf
    "Bending - When properly heated, molybdenum can be formed into intricate shapes. Moly sheets less than 0.020” thick can usually be bent at a 180° angle during normal room temperature conditions."
    And later in the same doc, under "Welding":
    "Note that if you weld the pure molybdenum in the open atmosphere, the material is at risk of absorbing the nitrogen and oxygen, thus causing oxidation and causing brittleness."
    So one gets the idea you should use a shielding gas if heating it significantly.
    I've only machined moly, not formed it. Good luck.
  3. Likes Strostkovy liked this post
    Mar 2011
    Geneva Illinois USA
    6,047
    2528
    2345
    Stainless would work as well and a lot less potential problems
    Tom
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,893
    1309
    549
    Quote Originally Posted by TDegenhart View Post
    Tom
    and a whole lot cheaper!
    we spin moly . has to be hot worked . we laser cut it , not sure about plasma (shears can fracture it , it doesn't waterjet cleanly) .edges have to be smooth to avoid fracture growth.
    even inconel would be easier to use.
    Jun 2016
    New York
    1,465
    802
    623
    nichrome and inconel are metals engineered for high temp. service, but even these, when subjected to the alternate reducing/oxidizing atmosphere of a wood stove hearth won't do well in thin sections.
    its hard to beat cast iron, time proven and cheap. seriously doubt pure moly would be remotely cost effective.
    Nov 2003
    Beaumont, TX, USA
    4,917
    171
    1495
    The great Swammi sees a small cast iron grate and four bolts (3/8"?) for legs.
  8. Likes Mtndew liked this post
  9. #7
    Jul 2006
    7,232
    1700
    5003
    I'd think a small cast iron trivet or furniture for pottery firing could be perfect.
    High Load | Bed Bath and Beyond
    2" Thick Square Kiln Post, 2" Tall
  10. #8
    Apr 2004
    Modesto, CA USA
    6,749
    1122
    I use a pinecone and a self lighting propane torch.
    Bill D
  11. #9
    Virginia
    26,177
    7561
    8249
    Quote Originally Posted by Bill D View Post
    Bill D
    Nah.
    MAPP gas, here.
    It's PM.
    We have higher standards to uphold than the average redneck!
    Using a "Red Dragon" (100% US-made, despite the Chinese-sounding name) don' need no steenkin' pinecones,..
    ...but is serious cheating!
  12. Likes Mtndew liked this post
  13. #10
    Oct 2005
    14,560
    Nah.
    MAPP gas, here.
    It's PM.
    It's not serious until LOX get's involved.......
  14. Likes Winterfalke, Locodad liked this post
  15. #11
    Apr 2004
    Modesto, CA USA
    6,749
    1122
    I would just get some stainless tube or rod. Drill a few holes in a firebrick and bend the rod to make a elevated grill. Or just drill some cross holes connecting in the firebrick. Perhaps a old cast iron gas stove burner or grate.
    Bil lD
  16. #12
    Apr 2004
    Modesto, CA USA
    6,749
    1122
    I do not bring my actelyne set with me when I go camping or have a picnic barbecue. A small propane torch, sure.
    Bil lD
  17. #13
    Oct 2017
    537
    138
    144
    Thank you for all of the alternatives, which I will probably pursue when this doesn't work.
    The goal here is to place two logs and a fire starter brick, light it, and then let it do its thing. My family is also less industrial in their antics than most folks here.
    To be honest there are a lot of solutions I skipped straight past on my way to molybdenum. Pretty sure I just like molybdenum.
  18. Likes Locodad liked this post
  19. #14
    Oct 2005
    14,560
    Bil lD
    No "acetylene set" needed Mr. "low information voter"
  20. #15
    Nov 2010
    Virginia
    121
    133
    16
    Ignoring all of the much more practical solutions, Mo is a really bad choice for this application. In inert atmospheres it is super capable of high-temperature use. In air, however, it oxidizes pretty readily, even at the temperatures in wood fires. Lots of "regular" metals would perform better.
  21. Likes Billtodd liked this post
  22. #16
    Virginia
    26,177
    7561
    8249
    Quote Originally Posted by Hightemp View Post
    So would a hunk of rock .... or a brickbat.... but "It's PM".
    Why trifle with "the ordinary" when failing at doing things the hard way is so much more interesting!?
  23. Likes charlie gary liked this post
  24. #17
    Oct 2017
    537
    138
    144
    Yeah, it seems like at the very least I need to choose a different metal.
  25. #18
    Jul 2006
    7,232
    1700
    5003
    Quote Originally Posted by Strostkovy View Post
    Just give the folks a supply of sodium and a squirt gun. Instant fire starter...
  26. Likes charlie gary liked this post
  27. #19
    Virginia
    26,177
    7561
    8249
    Too easy by half.
    Use a Moly laser-optics disk OUTSIDE the firebox ....aimed at the kindling.
    Bounce a sore-powerful laser beam off it, and .....
    Or go retro-tech, pre-Columbian Amazonian-Indigenous agro-plantation style:
    Light a naked Brazil nut "meat" and flick it in. No platform required.
    There's a reason their other name is "candlenut".
    Many others among the oilier nuts can be either food or fuel.
    You can literally get this job done for peanuts, even if you have to eat your mistakes.
