Hi all,
As im more a lathe person, but i have an old tos universal mill and i was asked to do a gear for the hand adjuster of a drill press.
The older gear had the tooths all broke and i took measure the best i could.
Everything good except that the gear need to go 3 mm towards the worm because its sitting on top of a slot.
My question is should i make a 45 degree angle.in the teeth or lower the diameter of them.
Thanks in advance
Thanks in advance
