Yearly tooling inspections
Results 1 to 9 of 9
    Sep 2003
    plantsville ct. usa
    498
    Default Yearly tooling inspections
    I work in an aerospace job shop as a gage calibration tech and I have a question about fixtures and tooling. We have a lot of weld, EDM and milling fixtures, none used for inspection that are in the calibration system on a yearly basis. My question is are most shops calibrating all their shop fixtures? The guy who did my job before me needed to work a ton of overtime and would calibrate a door knob if it would give him an extra 10 minutes of OT.
    Apr 2015
    Ohio
    97
    35
    Weld fixture calibration? You may have answered your own question with your last statement.... However I have seen the output amperage of welding machines "calibrated".
    Feb 2005
    9,215
    14843
    11028
    I can see a double check inspection before use if the fixture hasn't been used in many years,
    But, to pull a fixture off the shelf, dust it off and inspect it, and then put it back to be...
    Inspected Next Year... Again... for no reason.
    F'n Stupid.
    I've got a customer that used to (and they still might) send every thread gage they have out for calibration every six months.
    The stupid special thread gage that they bought 20 years ago for one job, and hasn't been used since.. has gone out to be calibrated 40 times for no reason.
    Its just what happens when people try and justify their jobs.
  4. Likes yardbird, gregormarwick liked this post
    Nov 2014
    Florida
    4,363
    1693
    2072
    Quote Originally Posted by Bobw View Post
    F'n Stupid.
    Yep, sounds like an overpaid QC/QA manager () trying to justify their 6 figure salary... at least where I have been that would be the goal.
    Other than incoming inspection if you had the fixture outsourced, and maybe an inspection if you start getting bad parts... Having it as part of a routine yearly inspection is asinine.
    Mar 2005
    Kansas
    7,832
    478
    3721
    Tag stating: Gage not in service. Calibrate before usage.
  7. Likes Bobw, Mtndew liked this post
  8. #6
    Dec 2008
    New York
    10,317
    2672
    Quote Originally Posted by rich p View Post
    most milling fixtures when tolerances require it are checked by probing or indicating. even fixture keyed to table slots if tight tolerance it might need a fine adjustment. I probably done a few thousand times over the years.
  9. #7
    May 2018
    36
    16
    Worked in aerospace for many years, our inspection guidelines were if any tool, fixture, etc. was used for product acceptance it had to be calibrated at least yearly. If it was not used for a two year period, went on an inactive tool list & recalibrate before use. Thousands of tools, gages, test equipment went through our calibration lab yearly. Warehouse full of inactive stuff.
  10. #8
    Dec 2008
    New York
    10,317
    2672
    Quote Originally Posted by E189552 View Post
    milling fixture can be inspected every second a billion times a year. still when bolted down to a machine it needs to be check then and there if tolerances require it. usually part of a setup check list.
    its like checking a airplane yearly..... still when pilot ready to takeoff he usually does a preflight checklist.
  11. #9
    Oct 2007
    SPAIN
    3,930
    2289
    1542
    About a year before i sold my place (so 3.5 years ago now) i had a flow-down from an instrument company (Aerospace) where their acceptance fixtures that we used, had to have annual calibration.
    This was for cockpit panel instruments - it mimicked installation - and if you've ever seen the float on Dzus Fasteners you'd understand that a wooden rule would be more than accurate enough
    I also was privy to some provisional blurb for machining fixtures (from same company) - wanting annual checks on fixtures which make their parts.
    This isn't a bad idea i guess - check fixture for general condition, and location pins for damage or wear and component fit etc, although i did explain we did that as standard practice every time we set the part.
    Of course, their reply was do you document this and if not why not - i said it was just good practice and yes- all good practice apparently needs documenting and turning into a works instruction and signing off etc...
