Line boring
Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Line boring
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    Default Line boring
    Does anyone have any interesting portable line boring pictures or stories? I have done center articulations, buckets, booms, frames and bores. Just thought I would share a few pictures and short clips.
  2. Likes cash, rvpa, Lumberjack, IronReb, hfo and 2 others liked this post
  3. #2
    Aug 2006
    montana
    389
    214
    154
    Question for you, is the white transmission cast iron or cast steel? If it's cast iron what wire are you running and do you over bore it before welding? Thanks for the pics Ron
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    This piece is cast steel. We were using .035" 70S-6 wire. I have never welded cast bores with a wire - only electrodes. I wonder if there would be a cast wire suitable for bore welding?
    Nov 2007
    Port Coquitlam BC Canada
    682
    11
    256
    Hi Trevor
    Nice work can you tell use about the welding unit maker and picture how small of bore and big can it do. Do you have to move it over by hand or does it advance on a feed setting ?
    Collector
    Jun 2003
    Mebane North Carolina USA
    6,662
    53
    1911
    Its a climax isnt it?
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    Default Line boring
    This is a climax bore welder - BW1000. It feeds automatically on a spiral and has a 1/8" pitch "lead screw". I think the range of holes is 7/8" up to 12". The smallest holes I have ever done were about 1.25" diameter and 1.5" deep. The limiting factor for larger holes is the rotation speed. I think there is a reduction add on you can get. The nicest part about this system is the integration with the climax line boring. You put your drive bar in the holes to be repaired. Slide cones over either end of the bar and into the holes for alignment. Weld on the bearings. Slide off the cones and remove the bar. Then the bore welder mounts to the bearings that are welded on. They are in line with the holes and ready for welding. After welding, you slide your bar backing through the bearings and start machining.
  8. Likes hfo liked this post
  9. #7
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    Default Line boring
    Here is a couple of pictures of a smaller hole. These were worn out threaded holes. I think they were 1-1/2" NC. I drilled them out oversized in the radial arm drill and then bore welded them up. Bored them out again in the radial arm drill to the tap drill size and then power tapped them. Not line boring, but an example of smaller bore welded holes.
    Trevor
  10. Likes AARONT, rvpa, Edgar10937, Lumberjack, sable and 4 others liked this post
  11. #8
    Aug 2007
    Wisconsin
    2,070
    1099
    927
    Nice work-thanks for posting.
    I assume most of the repair work you do is from when they don't properly lubricate parts in the field or just run it till it breaks?
  12. #9
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    Yeah. Majority of the repair is lack of grease.
  13. #10
    May 2005
    Republic of Arizonia
    1,587
    466
    Climax makes good machines.
  14. #11
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    They do. They have great customer service as well.
  15. #12
    Princeton, NJ
    375
    14
    329
    Just a quicky: what is the approx cost of the unit+welder, and the basic bar sizes you need to get normal work done?
  16. #13
    Mar 2005
    Palmer, Alaska
    3,603
    747
  17. #14
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    I am guessing the welder and line boring system would be around $15000....just guessing though. I can't remember what we paid for it.
  18. #15
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    I don't think a helicoil repair for this application would be as good a fix. I have actually never helicoiled any threads larger than 1".....
  19. Likes IronReb liked this post
  20. #16
    Jul 2009
    Peoria, IL
    11,716
    51
    8975
    You could always build your own line boring rig. We're all machinists after all...
  21. #17
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    Default Line boring
    Ewlsey....thanks for the awesome pictures. Before purchasing our Climax we had made our own unit as well, but nothing even close to as nice as this. What are you using to drive the bar? What rpm does it turn? What size bar is in the pictures?
  22. #18
    Jul 2009
    Peoria, IL
    11,716
    51
    8975
    It's a Skil 123 3/4" drill. It runs 375 RPM with no load. The picture shows a 1" boring bar which is great for this small bore on a Bobcat. I plan to make a 1.5" bar for bigger work.
  23. #19
    Mar 2013
    Washington
    287
    137
    197
    Lineboreing a boat transporter/Crain
    1.9375 boring bar at 22 rpm about a 8.5"bore
    Attached Thumbnails Attached Thumbnails img_0100.jpg   img_0111.jpg   img_0099.jpg
  24. Likes TheOldCar liked this post
  25. #20
    Nov 2015
    CANADA
    Saskatchewan
    20
    27
    18
    Default Line boring
    Great pictures!!!
    In the third picture looks like laser alignment? How does that work? I've never used any laser alignment equipment.
