What Does "Engine Lathe" Mean? - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 61
  1. #21
    Apr 2003
    Berkeley Springs, WV, USA
    4,291
    99
    Post
    Now, I am not a 100 per cent logical man. I like the poetic side of our laguage.
    I think the word "lathe" is one of the most beautiful words ever to discribe any tool, ever.
    "Engine lathe" is evocitave of heavy, masculine machinery. It conjures nostalgia of James Watt's shop and the immense challenges he and his men faced making machines that had never been made before.
    To this very day, I am almost overly proud to say.
    "Yes, I run the Engine Lathe"
  2. #22
    Jul 2006
    Arizona
    4,485
    18101
    4204
    Post
    >>The self-acting lathe, or engine lathe<<
    It was my understanding the term 'engine lathe' described a self-acting lathe meaning the lathe had it's own engine (or electric motor) powering it vs deriving it's power from an external source like the old school flat belt drives that hung down from the ceiling.
  3. #23
    May 2004
    45
    Post
    One might ask " doesnt a bench lathe do all of these things also". Maybe they should call them bench engine lathes.
  4. #24
    May 2006
    Rainier, Oregon
    934
    Post
    I don't seem then limited to ones with their own motors. --- I see it as a distinction from "foot lathes" which you had to pedal.
  5. #25
    May 2002
    Auckland, New Zealand
    4,424
    1506
    437
    Post
    gvasale, I have to comment on a couple of things....
    "Shop Theory" 5th edition, by James Anderson and Earle E. Tatro, copyright 1934, has the following: " The father of the modern engine lathe was Henry Maudslay who first invented the slide rest." He also combined the slide rest with the lead screw with change gears. " This took place in the early 19th century and made the the lathe the most important machine in the industrial revolution, for without the lathe James Watt's steam engine would never have been built. Because it machined the parts of Watt's engine, it became known as the engine lathe."
    No matter what your books say, steam engines were being made for over 100 years before machine tools came into common use. In fact, it was not until after the 1850's in the USA that machine tools were much used for engine manufacture.
    Cylinders were bored (though probably the first Newcomen cylinders were not bored), but almost everything else before this time was made by hand, ie chipped and filed, plus some hand turning (ie lathe without slide rest).
    I am not saying that engine lathes and planers were not in existance, they just weren't much used for steam engine (or other machinery) building, not in the US anyway, before the 1850's-60's.
    Another thing...James Watts experiments in Glasgow (and elsewhere) resulted in his invention of the seperate condensor (1765), this alone dropped the fuel consumption of the atmospheric engine to about 1/4.
    It was later that he came up with the double acting rotative engine (1783).
    One book I have (see below) suggests that an engine lathe is one driven by mechanical power, and also is "automatic" in operation, ie having a powered slide rest.
    A good book, though a bit of a slog, is Louis C. Hunter "Steam Power: A History of Industrial Power in the United States, 1780-1930".
  6. #26
    Apr 2006
    Montreal Canada
    896
    12
    Post
    An "Engine" lathe is a lathe driven by other than "Main Force" ie. person or other animal power. A "Plain" lathe without mechanical feeds or lead screw can still be a "plain engine lathe". All sparrows are birds but not all birds are sparrows! A cotton gin, and a spinning genny are both so called as a coloquiall diminution of the word "engine"
    Charles.
  7. #27
    Jul 2006
    Indiana
    18
    Post
    the gentleman that I trained under(20 years ago)
    his father worked in the "round-house" in Cincinnati years ago.
    This always made me think of engine lathe
    BY THE WAY ...........My Wife supprised me for my birthday with Reds tickets and an overnite stay.So glad our Son was able to join.plus they won
  8. #28
    Jul 2004
    Houston, TX USA
    29,077
    Post
    I have very old catalogs that show only line shaft driven lathes. They are described as engine lathes.
    John
  9. #29
    Dec 2002
    Monterey Bay, California
    10,260
    28
    213
    Post
    "I have very old catalogs that show only line shaft driven lathes. They are described as engine lathes."
    A lathe which is mechanically driven, whether a water wheel through a line shaft, or a motor through a line shaft, or a motor of whatever kind which is independent of a line shaft, is an engine lathe.
    A treadle lathe (man-powered) is not an engine lathe.
    A toolroom lathe is a higher accuracy version of an engine lathe, often having many more thread leads and axial or radial feeds.
  10. #30
    May 2002
    4,424
    1506
    437
    Post
    Philabuster,
    I may have misunderstood you, but the term "self-acting" in the case of the lathe (as far as I have read) refers to the powered slide rest, ie what we call power feed to the carriage. It does not refer to the means of powering the spindle.
  11. #31
    May 2006
    northwest ARK
    2,956
    4172
    404
    Post
    From what was told to me years ago and makes sense is: A lathe that sits on a bench, when you turn on the motor the spindle starts turning
    ( like a bridgeport mill ) isn't an engine lathe.
    On an engine lathe the spindle starts turning when you pull a lever, push and arm, or step on a control arm.
    The power is already there from an electric motor, water-wheel powered shaft, windmill, hamster in wheel, dog on treadmill, etc.
    The clutch is engaged to start the spindle turning.
    Hope this helps,
    Jackal
  12. #32
    Oct 2004
    St. Peters, MO
    2,972
    157
    140
    Post
    I was told simply that Engine lathe was short for "engineers lathe".
  13. #33
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,201
    2753
    5545
    Post
    Well I guess if "you were told" this, it must be the real deal huh ? Doesn't matter by whom... :rolleyes:
  14. #34
    Oct 2004
    St. Peters, MO
    2,972
    157
    140
    Post
    Well Don, if you MUST know "who" told me, I shall reveal my "source".
    His name is Charlie and he was a watchmaker for more than 2 decades and then went into micromachining building machines that manipulate DNA and other genetic materials. "He" told me that "if you ever hear the term 'engine lathe', it means nothing more than 'engineers lathe'.."
    I guess he must just be some dumba$$ that doesn't know anything!
    Sure seemed to know what the hell he was doing. He was building some machines that extrude glass so small they us them for pipetting to wihtdraw genetic material in eggs for in-vitro fertilization...Then again, he may have just been making that up!! How stupid of me :-O--Grant
  15. #35
    Dec 2000
    51,201
    2753
    5545
    Post
    He could be the smartest man that ever lived and still not know the historical origins behind certain English machinist terms. After all, he wasn't alive when the term began to be used.
  16. #36
    Oct 2004
    St. Peters, MO
    2,972
    157
    140
    Post
    I hear ya!
    I was just throwing another option out there that was not mentioned. I did not make it up. I figured that if he had used these types of machines, he may have a clue on origin.
    Now, if "I" had thrown it out there then, yes, it would've been a dumba$$ thing to say as I have little knowledge of this.
  17. #37
    Aug 2006
    Brisbane, Queensland
    1,288
    Post
    As far as I know "engine" lathe is a US invention. In Britain and here the term is Centre Lathe. I'm happy to accept any suggestion except we had an old treadle lathe and it definately had change gears and a lead screw.
    Engineers lathe sounds good to diffentiate from wood lathe.
    On the subject of early steam engines I understand that they were not a mechanical device like a beam engine that used pressurised steam to drive a piston to produce rotary motion.
    I think the early steam engines used a difference in pressure to extract groundwater from coal mines.
    This brings up the definition of an engine. I've seen several references to an engine and a motor in other threads and I'm sure lots of folks have definate ideas on the difference. I can't recall any "self-actuating" characteristic as a difference but "self-sustaining" in the case of an internal combustion engine seems reasonable.
  18. #38
    Dec 2000
    51,201
    2753
    5545
    Post
    Damien, I like Centre Lathe better...make more sense really....except you misspelled "Center"
  19. #39
    Aug 2006
    1,288
    Post
    And you misspelled mis-spelled. [img]tongue.gif[/img]
  20. #40
    Aug 2006
    1,288
    Post
    Memory now drags into this time the expression "computing engine". So I am happy to accept "a mechanical device" for the meaning of "engine". Something that will convert an input to a different output.
    How's that! As they say at the best cricket matches.
