12 GA From Hell - Page 25
Page 25 of 26 FirstFirst ... 1523242526 LastLast
Results 481 to 500 of 514
Thread: 12 GA From Hell
  1. #481
    Mar 2006
    Brinton, MI
    401
    9
    A 585 HE ...shot with moderate heavy load......
    https://scontent.cdninstagram.com/t5...09533184_n.mp4
    Here is a 375 HE target gun set up, by Asteroid Precision...
    Here is video of it being tested... And with a 350gr bullet about 3450-3475,
    bolt opened easily with one finger...And he's just getting started
    and is checking on better powder, Ed..
    Finally got to do a little load... - Asteroid Precision Rifles | Facebook
  2. #482
    Mar 2006
    Brinton, MI
    401
    9
    Here is recap simple setup to get faster loads with 12ga sabots
    & slugs, Example using break actions...., reaming chamber
    in a 12ga break action to 3.5" with a 3.5" 12ga reamer, that isn't
    something needing special order, and use 3.5" plastic cases , or
    get 3.5" brass cases made. With mag shotgun primers and
    our slower powder loads you can get a quarter more speed,
    which gives 50% more energy...
    585 Hubel Express video, 190ft/lbs recoil, heavy load, gun little light.....
    .585 Hubel Express 19ft/lbs recoil - YouTube
    Another view of Asteroid Precision's.... 375 HE target gun,
    Here is our 416 HSM we are developing next to 416 Barrett, Ed
  3. #483
    Feb 2007
    Myrtle Point, Oregon USA
    340
    55
    249
    Quote Originally Posted by abarnsley View Post
    I would want a clarification from BATF&E
    Destructive device - Wikipedia
    Looks like a DD to me................If its rifled
    almost positivly a DD
    No doubt a destructive device...I once was in a shop when an old gent was showing off a similar project...mentioned that it was probably illegal, he looked at me like I was nuts. Several months later I was told he was contacted by the government and made to cease and desist....
  4. #484
    Mar 2006
    Brinton, MI
    401
    9
    We get an ATF exemption, sporting exemptions for our cases.
    Here in picture of the cases, are shown the steps in making
    our 416 HSM case, from BMG brass,, Ed
    We might have a company that is doing a bolt gun with an action
    between BMG size and longer rifle actions used for 375 HE,
    375 Lethal, and Cheytacs.. To use for our 416 HSM without
    having to do extreme rebating of the rim.
    Here is picture of 620 416 hsm cases half done. Done on cnc ,
    that slimmed them down, cut new rim and extractor groove.
    There are over 500 more at cnc getting done now, plus we have
    1000s more bmg cases we make them from, when needed..
    This case is public domain and if anyone wants to make
    them we can give the steps involved...Ed.
  5. #485
    Mar 2006
    Brinton, MI
    401
    9
    For big long cases our testing is showing that the 416 easier to get powders to work with, less problems ..
    Maybe building a target gun,don't have 375 barrel all ready, maybe go 416....
    We got cases, 416 HE and 416 HSM, as well as 375...
    CEB and others will have bullets...CEB will be doing .416 in 450gr, 475gr, 500gr, 525gr and 550gr
    Got sent 5 thick sided sample cases, same OD base as 585/375.416 cases, same belt, just .180" longer,
    did a 416 HE, chambered extra barrel , cases stick over 50k. They have about .042" total taper, .021" per
    side, when I necked couple to 416. That is a lot of taper , twice the taper of my 416HE...hanging up at 50k..
    I could maybe go to 65k with these if we made taper with ..012" - .016" more taper to each side, but that is
    no way to build target cases. I'd have to crunch down case shoulder diameter. And would look like 30-30.
    And crazy part is, the case has enough brass material to thin up sides and stretch them way out to 4 or
    more inches,, They weigh 150 gr more than our 585/375/416,, but with real thick sides they actually
    hold less than our 416 HE with thin sides, that is .180" shorter...Our case does 65k ok without sticking..
    And we can make super long 4" cases work if we had means to get them built, as we have
    15 powders slower than HBMG.Here is pic of thin and thick sided cases, sectioned for comparison.Ed..
  6. #486
    Feb 2014
    Minneapolis, MN
    694
    124
    210
    Hey, I keep running into trouble finding actual 12gFH load data
    Got a 210 and a real heavy 12g rifled blank, been thinking on toying around, just haven't seen what you guys have found to work good, I remember you were having trouble with some powders needing a small amount of pistol powder to properly light off.
  7. #487
    Mar 2006
    Brinton, MI
    401
    9
    What we found works good is 3.5" plastic and brass cases, RE17
    powder, 600gr slug use 105gr in plastic, 130gr in turned brass,
    Here is a drawing depicting the layout of thick and thin sided cases,
    like my 585/375/416 HE thin sided ones and the thick one in picture.
    And my 585 case is not perfect, as where it transitions from the
    heavier corner to the side it isn't gradual, so case separates there
    shortening case life. There are others made that way including brand X.
    The dotted line is what it should be............
    Others have sent cases to section and look at, that are built thick sided and they
    stick also for the folks, If a longer case with about 5 sq in of side surface sticks and
    don't spring back, the coefficient of friction is about .01 then the pull needed to move
    it is 2500-3500 lbs..That is for big cases with normal amount of slant to the sides.
    Here is picture of six nyati and gibbs size cases sectioned.. the5th one is present 585 HE
    and 6th is thick sided version. 1st 600 OK which essentially nyati basic case left straight, belt added
    In the picture the nyati gma is one we built most of our first 585s on. Before we had factory run.
    Reworking made it in size that is my 585 HE, but that brass had the sides of perfect thickness,
    not too thick, but thin without sharp transition my new factory 585s had, they last forever as 585s......
    Fourth one is an older nyati case I used to make about 10 of my 585s from,had thin sides, heavy corner
    and sharp transition from the corner, tested 20 years ago, and they would separate after 4-6 hot loads
    as 585s, my factory 585 with right powders, as a 585 will get 10 hot loads, and necked down to
    416/375 4- 6 hot loads, right powders used, Moderate 577 equivalent, factory 585 at least 20 loads..Ed.
  8. #488
    Mar 2006
    Brinton, MI
    401
    9
    Guy sent thick sided 375 case, next size base diameter up from Nyati.He said,
    'Yes I ran them in a ___________ rifle built by ____, the best I
    could get was 44000 psi, any more and they were stuck''
    Big bore guys. other forums over the years related that trex/african case in 585
    size, thick sided cases, stuck when they loaded them over 45k psi.
    Another just sent us, thick sided 375, long case, same base OD as our 585 HE,
    416 HE, 375 HE, and Mitch's 375 Lethal, and the thick ones stuck over 45k psi.
    Now you can fill those cases up, with ultra slow enough powder so they won't
    stick, but powder is too slow for max speed. Might get a little more
    speed, with thick sides case, but case got to be 4- 4.5 inches long..
    . Anyone needing a sectioned case of the ones I made the first of my 585s from,
    contact me, if they want to get a general idea of what case side thickness should
    be, in Gibbs size cases on up to about trex and 375 VM size case diameter.
    Here is pic of our 585 based case next to brand X and thick ones, both have
    same sharp, thinner, corner, where transition from heavy angled corner, to the
    side, the carbide draw rod could easily be reshaped with diamond wheel,
    just by grinding off sharp transition corner. Then sides would be perfect.., .
    Here is picture of 416 HE in a Choate target/varmint stock guy is doing,
    using long action BSA U9 action.Setting in stock ready to do bedding..Ed
  9. #489
    Mar 2006
    Brinton, MI
    401
    9
    Here is picture of thick 375 case sent to me, with thick sided trex case, and our HE case,
    The thick 375 case is .050" bigger OD base, but inside is no bigger than HE cases..
    These thick sided 375s stuck for the guy using them, when loaded over 44,000 psi....
    Got guys asking and doing it, to do 416 HSM case for BMG actions, so leaving rim same,
    as the original bmg rim, so will neck them, fire form to the longer shoulder, like the others.
    Base a little bigger, Shoulder same diameter, same 30 degree slant, neck will be same..
    Inside of case still has close to same shape, volumne within 3 % as ones we slimmed down more.
    Some want to use bmg actions and can't wait for intermediate actions, or already have bmg action.
    And they are really getting interested in the complete line of 416 CEB bullets now being done
    clear up to 550 gr...
    So there will be 3 versions, one for actions .750" bolt, one for .800-.850" bolt,
    And one for bigger bmg bolts. The ones for BMG called 416 HSM2 ..
    Here is 416 HSM guy working in a Montana PH, in a heavy thumbhole target stock. Ed
  10. #490
    Mar 2006
    Brinton, MI
    401
    9
    Here is sectioned 585 HE case in the middle, we first made from
    another case, years ago before we had factory run of brass and
    it had perfect thickness on the sides and inside corrner.
    We could fire them many times without sides thinning..
    First case is factory run of our 585 HE, 3rd is case that is too
    thick of sides and sticks at high pressures..
    Pic of our factory run cases necked down to 375 and fired 4 times
    at high pressure on the right, with unfired case on the left.
    Our case is not perfect but does work...Ed
  11. #491
    Mar 2006
    Brinton, MI
    401
    9
    About 416 cal bullets............
    The heaviest 550 gr for Extreme ELR probably be best 8 to 1 twist , in 416 caliber bullet,
    and 520 gr 9.5 to 1, and 470gr 10 to one, Some barrels I picked up are 10 to 1.......
    Now a novel idea is to lighten rear of bullet with small shallow hole drilled in base, might do better
    long range.which would allow 10 to one barrel stabilize the heavier 550 gr bullets for ELR.
    Making bullet nose heavier makes it more stable in flight, needing less spin,
    like our hollow base 585 cal minie bullets only need 48 to 1 twist, or less
    while out regular 585 bullets need about 24 to 1 to stabilise them..............
    The winner of the King Of 2 Mile shoot last week was using 416 Barrett with a 1 to 10
    twist, with a 500 gr CEB Lazer bullet, ...Robert Brantley, with Manners Stocks....
    Paul Philips was third with a 416...
    GOOD NEWS-- There is now an importer and seller of our 585 HE brass getting set up here,
    in US, hopefully will be in stock, few weeks........ Home - Bertram Brass .. .. Caleb Hallet..
    Have got another intermediate size action besides the Montana PH our guys working on,
    to do speed testingwith. It is big long REM style action that can take our 416 HSM, ED
  12. #492
    Mar 2006
    Brinton, MI
    401
    9
    Experimental intermediate size action with the Montana PH, for comparison.
    It is an experimental action for our 416 HSM, to do our speed testing with
    and get a better action than Cheytac size actions, for bigger case ELR use,
    without going all way up to more expensive, huge actions.
    It is big long round style action that can take our 416 HSM, almost
    1.6" diameter and .800" bolt, with locking lugs nearly as big as most
    BMG actions.... ED
  13. #493
    Mar 2006
    Brinton, MI
    401
    9
    Here is picture of the bolt from the experimental action,
    with our 416 HSM case in it. Note the amount of the
    base size of locking lugs, the amount of area on the bolt..
    Here is link to guy doing special 585 HE in the EU,
    Good pictures............www.585he.cz
    We tested intermediate action with a 700HE barrel we had here.
    Just temporary to test strength. 1000 gr over 3100..
    Action worked fine.. Ed.
  14. #494
    Mar 2006
    Brinton, MI
    401
    9
    Here is video of early water barrel test of the
    12ga From Hell, from years ago.
    Grandpa's First Shot - YouTube
    Here is picture from that video..
    Here is the intermediate size action for 416 HSM with test barrel, .Ed
  15. #495
    Mar 2006
    Brinton, MI
    401
    9
    In 416 HSM got a 415 gr long target bullet 3800,
    with plain barrel, no brake, on intermediate action,
    Now my 416 HE gets same 415gr bullet to 3300.Ed
  16. #496
    Dec 2018
    Indiana
    10
    MAN, you are awesome! I am now 100% building NEF 12gaFH. I got some questions though, if you don't mind lending me a hand.
    So the plan is to use an NEF/ H&R 12 Gauge Ultra Slug. I am more than likely going to have a barrel made. I want the largest barrel profile the NEF can handle with an overall length of 30". More than likely it will be stainless steel.
    Now for my questions.
    Can the NEF handle the monster 3.85" case, or is it only safe to run 3.5"? If so, what are the chamber dimensions so I can pass it on to my smith.
    What would you consider a maximum load for the NEF? And what powder are you using or would recommend?
    What primers are ideal for the RMC brass?
    What if any wadding/cards/fill are you using if any?
    I am sorry for all the questions, but I am wanting to get my info from the source so I don't get confused or read info wrong while pouring over the thread. Thank you so very much for any info you can provide.
    Richard
  17. #497
    Dec 2018
    Indiana
    10
    Also what reloading equipment are you using, and how do you crimp the slugs?
    Are you using a roll crimp?
    I have an RCBS rock chucker that I use for 458 lott. Are you using the cowboy dies?
    Richard
  18. #498
    Mar 2006
    Brinton, MI
    401
    9
    For plastic cases we use shotgun sizer and roll crimp.
    We use roll crimpers in drill press wit a clamp to hold case.
    NEF SB2 ULTRA already has the heaviest barrel the action can fit, it
    is a straight bull barrel, and best using 3.5" brass and plastic cases.
    Just tell smith to use regular 3.5" reamer that all the industry uses.
    In NEF you just use it to go from 3" to 3.5"... The cowboy dies are only for
    thin brass cases, so with full thickness 3.5" brass dies use the die that
    RMC makes to go with the cases. Mag shotgun primers work fine with the
    rifle powders we found that will work,, RE17, IMR 4759, VV110,,,, Ed
  19. #499
    Mar 2006
    Brinton, MI
    401
    9
    Here is picture of our 416HSM cases with screw in shellholders,
    for Ammomaster, etc, and slip in shellholders for regular presses
    Also have some for big LEE Classic and Smart Reloader presses..
    A 378 WEA MAG in picture for comparison...
    Second is stacks of 416 HSM, about a third fireformed
    and the rest to be fireformed... So far total about 1700, Ed
  20. #500
    Dec 2018
    Indiana
    10
    Thanks for the info sir! So are you using any fill? What's a good starting point for a powder charge so I can work up a load safely. And what roll crimp are you using for the drill press? Are you saying you use it on your brass cases as well?
