12 GA From Hell - Page 26
Page 26 of 26 FirstFirst ... 16242526
Results 501 to 514 of 514
Thread: 12 GA From Hell
  1. #501
    Nov 2012
    Michigan
    608
    196
    179
    Quote Originally Posted by elysianfield View Post
    No doubt a destructive device...I once was in a shop when an old gent was showing off a similar project...mentioned that it was probably illegal, he looked at me like I was nuts. Several months later I was told he was contacted by the government and made to cease and desist....
    One has to read the whole law...
    "(f) Destructive device
    The term “destructive device” means (1) any explosive, incendiary, or poison gas (A) bomb, (B) grenade, (C) rocket having a propellent charge of more than four ounces, (D) missile having an explosive or incendiary charge of more than one-quarter ounce, (E) mine, or (F) similar device; (2) any type of weapon by whatever name known which will, or which may be readily converted to, expel a projectile by the action of an explosive or other propellant, the barrel or barrels of which have a bore of more than one-half inch in diameter, except a shotgun or shotgun shell which the Secretary finds is generally recognized as particularly suitable for sporting purposes; and (3) any combination of parts either designed or intended for use in converting any device into a destructive device as defined in subparagraphs (1) and (2) and from which a destructive device may be readily assembled. The term “destructive device” shall not include any device which is neither designed nor redesigned for use as a weapon; any device, although originally designed for use as a weapon, which is redesigned for use as a signaling, pyrotechnic, line throwing, safety, or similar device; surplus ordnance sold, loaned, or given by the Secretary of the Army pursuant to the provisions of section 4684(2), 4685, or 4686 of title 10 of the United States Code; or any other device which the Secretary finds is not likely to be used as a weapon, or is an antique or is a rifle which the owner intends to use solely for sporting purposes.
    Please see: https://www.law.cornell.edu/uscode/text/26/5845
  2. Likes RichardF liked this post
  3. #502
    Mar 2006
    Brinton, MI
    401
    9
    Bob Snapp, 90, the great Gun Craftsman, of
    Clare, Michigan, passed away Jan 28th....
    He was an esteemed member of the
    American Custom Gunmakers Guild,
    Being its president in 1992..He liked
    working with Martini Cadet singleshot rifles
    .Worked with guys testing armor long time ago.
    Maybe the 1st to do 20mm necked down to 50cal
    We lost a great friend,,,Ed
  4. #503
    Mar 2006
    Brinton, MI
    401
    9
    We use cards and wads in both plastic and brass 12 ga
    where needed, No airspace ever, For 4759 powder start at 75gr
    no less for slugs up to 750gr, For RE17 start at 105gr, no less,
    for slugs up to 750 gr, the roll crimper is steel ones
    ballistic products and others have, use only on plastic.
    For brass cases we size them so slug nas real tight fit. Ed
  5. #504
    Mar 2006
    Brinton, MI
    401
    9
    It is possible rig up holders for many types setups.,
    About shellholder supply for big cases,
    RCBS and others make slip in holders for shotgun cases
    that can work or reworked for big rimmed rifle cases...
    Here are various sizes.......
    16ga-- .810" rim,........ 20ga-- .760" rim,....
    24ga-- .725" rim,....... 28ga .680" rim....
    Ch4d and Buffalo Arms also have these larger shellholders...
    We fireform the 416 HSM with 65 gr of medium speed
    surplus powder, with rest of case filled with farina
    and grits mix, with a play dough plug in the neck.
    It is loud, so we shoot it into big container through a barrel size
    size hole, so the sound is muffled, so it doesn't deafen us..
    It is great getting more companies making 416 caliber bullets,
    long target and bore rider bullets. Ed..
  6. #505
    Mar 2006
    Brinton, MI
    401
    9
    HERE is a video, 585 Hubel Express and water jugs - slow motion
    750 gr with 155gr RE17, just a moderate load.....Ed
    YouTube
  7. Likes lazarus liked this post
  8. #506
    Mar 2006
    Brinton, MI
    401
    9
    20mm Vulcan is a big case that works ok, without having
    the sides made too thick...They have thinner sides
    than smaller cases guys are getting that have the sides
    made too thick and won't extract easy or work with high pressures.
    Here Barnard P Cheytac bolt that would do for our 416 HSM..Ed......
  9. #507
    Mar 2006
    Brinton, MI
    401
    9
    Got guys doing various 416 HEs..
    One just built a 416 HE, just been testing it a few days..
    And using 168gr of HBMG 475 gr CEB, tested it, in good
    conditions, 2 shots at 1800 yards and was within
    a 1/4 of minute accuracy...A few shots at shorter ranges
    had same accuracy. Ed..
  10. #508
    Oct 2014
    Massachusetts
    75
    80
    54
    lol at 12 GA from hell ... try 1GA from hell.
  11. #509
    Apr 2011
    Nebraska
    1,267
    1840
    376
    Quote Originally Posted by _boris_ View Post
    Love it! The perfect "home defense" weapon.
    -Ron
  12. #510
    Mar 2006
    Brinton, MI
    401
    9
    More about our 416 HSM from BMG brass, and
    our 416 HE & 460 HE from our 585 HE cases
    Got reamers for 375 HE, 416 HE and 416 HSM,....
    460 HE & 460 HSM are all spec'd, got HE reamer
    soon have HSM reamer...Our HSMs have a Wea type
    radius on the shoulder..
    The fellow that set up our 416 HE in an ELR rifle
    and got 1/4 min accuracy,
    They got some game out west over 1400 yds..
    .Here is the gun they set up.
    Using a K&P 34" barrel on a BAT action.....Ed
  13. #511
    Mar 2006
    Brinton, MI
    401
    9
    And have got a 460 HSM figured out, and the impetus for that is some
    asking about one and the great line of 458 bullets CEB now has.
    It will hold more powder than the 416 HSM.....Ed..
  14. #512
    Mar 2006
    Brinton, MI
    401
    9
    The guys that did the super accurate 416 HE did another
    416 HE that has an 8" longer 42 inch K&P barrel..
    Used a Stiller action and same load with 475 gr bullet, as in
    first gun and and gained about 200 fps with good accuracy.
    3065 fps. Tested 2 groups of 3 and less than 1/2 min moa.
    And loads they used are not the highest speed loads
    the cartridge is capable of....Here is print with specs for
    the 416 HE reamer chamber ....Ed....
  15. #513
    Mar 2006
    Brinton, MI
    401
    9
    More about he guys that did the accurate 416 HE, they did a
    Used longer barrel and the same load with 475 gr bullet, as used
    in the first gun and and gained about 200 fps with good accuracy,.
    the cartridge is capable of....Here is picture.......Ed....
  16. #514
    Jan 2008
    McKenney, Va
    706
    152
    69
    Default your 12 ga from hell inspired my 410-444
    I've followed your thread from the beginning. I too live in a shotgun only county and thought, I sure would like too have rifle performance from a shotgun. Being right handed and right shoulder is too wore out for more than 2-3/4" 12 ga shells, I had to take a different route.
    Long story short, I had a Rossi 7.62x39 that was too deep chambered from the factory, so I hacked the barrel off and bored the stub and threaded it for 7/8x14. I took a H&R 44 barrel blank and turned it down to the stub diameter and threaded it with a comfortable shoulder to mate in the stub. Devcon mess and a good torque and next day, back to the lathe to trim excess to match stub. I didn't have a 410 chamber reamer, so I recut the profile of a #8(maybe #9, don't remember) taper pin reamer for 2-1/2" 410. Step drilled chamber then reamed it. Felt good on receiver, so of course I had to try it. 2-1/2" #6 shot patterned like a blunderbust. I cut the extractor slot and only had to trim the corners of the extractor. Mounted a 3-9x40 scope and testing time.
    The H&R blank was a 1 in 38? twist. Too slow for the 444 marlin and I don't mind a bit. This gun weighs 8.8 pounds before scope and mounts. I wouldn't even think about shooting it out of a lever gun. Reloaded the cases with wheel weight lead 44 casts sized at 431 and 255 gr. and it shot ok, but keyholed at 44mag loads.
    My final decision was to go to shotgun hulls. 3" new win super x cut to 2-1/2. Depth set on drill press and a quick down and out with a 7/16 straight flute reamer at 95 rpms took just enough out to make the slug snug. Add 9gr. universal, cardboard, grits, card and the slug. It leaves enough plastic around the slug to squeeze it for the last 3/16", so no glue necessary.
    It shoots clover leafs at 50 yd and last fall turkey season I took a hen at 65 yd thru the neck. It also shoots brenneke slugs all in the same spot at 50 yd, but they don't have any punch after that. The reason I went with 44 cal is saami specs for a 410 bore are .410-.430. Having a .423 bore makes it a legal 410, even if you can pump a 255 gr slug vs a 87 gr pellet.
    It was a fun project and it is a useful gun for the dense area I have to hunt in. I thank you for the idea. I will try to load a pic of it before I blued the barrel.
    hope that worked, it's been a long time.
    Disclaimer: Don't try this with a shotgun metal receiver. Mine was a rifle from the factory.
