1903-A3 Floor plate release
Likes Likes:  0
Results 1 to 5 of 5
    Apr 2009
    CA USA
    127
    12
    Default 1903-A3 Floor plate release
    hello , I have a 1903-A3 & I would like to make a release button for the floor plate . I not a bug fan of the wardens slamming my bolt back & forth to check my rifle. anyone have a drawing that I could make a release button from ?
    thanks
    animal
    Aug 2004
    ventura,ca.usa
    476
    120
    Animal, it might be easier to use an 03 milled floorplate rather than modify the stamped A3 one, not exactly correct but it does not sound like you are restoring anyway.Jim
    Apr 2009
    CA USA
    127
    12
    Thanks JMM03 , someone like Brownells would have milled floor plate ? I would still need a release of sorts though ?
    thanks
    animal
    Jul 2018
    Wisconsin
    248
    68
    185
    If I recall correctly, the Springfield floorplate release is similar to that of the Mauser. A bullet nose is pushed into the recess at the rear of the floorplate, depressing a button, allowing the floorplate to be slid to the rear, where it is released from the front of the trigger guard, allowing it to drop downward. Brownell's used to offer an easy install button for the Mauser floorplate release. Such a thing might be fabricated for the Springfield. Taking measurements off your rifle should be easy. Envisioning the piece is the trick. Perhaps someone can assist with a photo.
    Aug 2004
    ventura,ca.usa
    476
    120
    Animal, the milled triggerguard was used on the 03 and can be found in a variety of places, Trigger Guard, Steel, New Reproduction | Gun Parts Corp. is one of them. Note that the one referred to is a reproduction and there are several other parts you would need to purchase to go along with it. This forum is also an excellent source of info and parts: M1903/1903A3/A4 Springfield Jim
