Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I have a new unused Caspian 1911 frame. Has ejector installed, I can see it's held in with roll pin. I want to remove the ejector however using a Starrett 1/16" pin pinch or a Snap-On roll pin punch both jam into the hole in the roll pin. I tried the next size in the sets 3/32 but they are too big. I know they make 5/64" roll pins but when I try the back side of a 5/64" drill it will not fit in the hole! #50 (.070) drill will not fit but #51 (.067") will fit. But if the roll pin is 1/16" the punches should not get stuck inside them. Any ideas on how to get the Ejector off?Only thing I can think of is to cut it out with a 5/64" carbide end mill.
