A little background first. I’m a journeyman tool and die maker, plus I have taught blueprint reading and CNC to apprentices and college students. I’ve downloaded the prints for the 1911. Is it just me, or are the blueprints as confusing to you as they are to me? Maybe I’m missing something, but I can’t find a simple overall height of the slide. There appears to be no dimension that originates at the top of the slide.
I’m going to machine the slide cut for a new Trijicon red dot, the RMRcc. Its design goal is for single-stacks. It works for the sub- and micro compact pistols that are hitting the streets, as well as the 1911. It’s narrow enough to fit within the profile of the slide, so an adapter plate is not needed. The way the sight is designed the locators and tapped holes are combined into two posts. No need to drill and tap into the slide. So, my quandary is how deep I can cut, so no suppressor height sights needed, without getting into the extractor or firing pin holes. Here’s where I get lost in the blueprints. I should just print them out, so I don’t have to flip between screens. Or, just bite the bullet and buy the CAD drawings.
This is where the no adapter plate is really a great setup. I’ll be losing my rear sight dovetail. Well, how about a “reverse” adapter plate? I intend to leave a buttress at the end of the slide as an additional recoil lug. Now I can machine a plate that has the dovetail so I can switch between red dot and irons.
