300 Blackout AAC muzzle thread.
Results 1 to 8 of 8
    Oct 2013
    Johannesburg, South Africa
    92
    9
    Default 300 Blackout AAC muzzle thread.
    Hello all,
    I have 300 Blackout Advanced Armament barrel where the owner would like the muzzle brake removed.
    Please can someone tell me if it has a left or a right hand thread.
    Vincent.
    May 2014
    34
    5
    7
    Quote Originally Posted by Vincent Phipson View Post
    Hello all,
    Vincent.
    Should be right hand thread. It's not uncommon to see them fixed with red locktite, rockset, etc. They will all break down with heat. How much heat depends on the compound.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Nov 2011
    2,200
    1412
    2828
    Mine had right hand.
    You shouldn't need much "oomf" to break it free. They almost assuredly use Rocksett, which doesn't require much torque to break. Comparable to blue loctite, actually weaker, but quite significantly more heat resistant.
    Assuming it's factory installed, and not installed by a random Bubba or Bloke.
    Oct 2013
    92
    9
    Thanks for the replies. At least I know which way to turn it.
    Apr 2008
    West Coast
    307
    62
    56
    If you think there may be rocksett used, do yourself a favor and soak the joint in water overnight before turning it.
  6. Likes 300sniper liked this post
    Jul 2017
    I think you will find the muzzle threaded a conventional 5/8th 24tpi. AAC was having a sale recently on the lightweight 300 Blackout barrels they were installing on Remington 7 actions (looks like Remington discontinued that model.) I bought one. Under the included thread protector, it was threaded like any AR-10's muzzle.
    Aug 2007
    5,201
    1142
    1026
    Quote Originally Posted by clm2112 View Post
    It usually is, but doesn't need to be. Most people use common 308 muzzle attachments which are 5/8-24, but nothing to stop anyone from using different if you're making a custom thread protector, flash hider, or brake. For common parts you are absolutely correct, AAC barrels have always been 5/8-24, at least all the ones I've seen and own.
  9. #8
    Apr 2017
    Something to consider, if the barrel its self is shorter than 16,(from face of bolt to end of barrel) the muzzle break will most likely be permanently attached via a spot wield or a blind pin. If you remove the breake you will be making the barrel illegal unless it's registered as a SBR with the ATF
  10. Likes MikeS-54 liked this post
