Although the title may seem dramatic and the answer obvious at first glance I want to tap the knowledge on this forum once again. I haven't had much luck finding a used 50 chamber reamer so I will be going with a new one after all!
That leads me to the big question, which chamber should I go with?? I've asked a few manufacturers for specs on their rifles and the consensus seems to be that 50 US Ordnance is the common size, although I also like the idea of the US Ordnance match size (smaller neck and shorter freebore).
The issue here is that I'm not sure if the match chamber size will allow me to utilize bulk ammunition like XM33 and the such. If any of you have had experience with this I would appreciate your input! Thanks
