50 BMG Firing pin info ?
Results 1 to 8 of 8
    Jun 2019
    UNITED ARAB EMIRATES
    Default 50 BMG Firing pin info ?
    Does anyone know of a Firing pin info for 50 BMG ?
    Firing pin travel?
    Firing pin tip diameter?
    Firing pin protrusion?
    Mar 2006
    New Jersey
    1,149
    14
    349
    For what type of system? M2, M107, Universal Receiver? Each is different. I have a chart at work, can get it Monday.
    Nov 2012
    Michigan
    615
    208
    184
    Quote Originally Posted by sas77 View Post
    Firing pin travel?
    Travel is NOT what you really need... Striking force is. I don't recall where I got this info, but I found 100in/oz as a spec. for one of the .50BMG primers (may have been from one of the GD guys, may have been some idiot on the web). I used that in my BMG and have had ZERO FTF, ZERO hang-fires and ZERO pierced primers. I can't say that the number is right or wrong, but it has worked for me.
    I looked at about a dozen .50BMGs and found them to be using a striker diameter of between .075" and .090" I decided to take an average and settled on .080". This is approximately what most I looked at were using. Again I have had ZERO issues.
    Again I compared MANY different .50 BMGs as well as other rifles. I found that generally protrusion was roughly equal to striker diameter. Based on MY findings I went with .080".
    Again I can NOT say that any of this is much more than "by guess and by golly". But it has worked for me. Use at your own risk. I still consider my .50BMG prototype / experimental firearm.
  4. Likes sas77 liked this post
    Jun 2019
    Quote Originally Posted by MilGunsmith View Post
    Bolt Action Rifle
    Jun 2019
    Quote Originally Posted by MIBill View Post
    Excellent synopsis, thank you for this information!
    Work on a new model similar to the steyr Hs-50, with a change in the mechanism of action
    Nov 2012
    Michigan
    615
    208
    184
    Mine is basically a scaled up 700 with a few tweaks. Fun project!
    Mar 2006
    New Jersey
    1,149
    14
    349
    According to USGI specs for ammo acceptance testing using a Universal Receiver: Firing Pin Protrusion is .074" to .082", Firing Pin Indent is .020" to .025" in a SAMMI spec copper cylinder. Firing pin diameter is .077" to .078" with a nose radius of .040" to .045". This will ensure ignition of USGI Ammo.
  9. #8
    Jun 2019
    Thanks, MilGunsmith, that's exactly what I was looking for! You, sir, are a gentleman!
