7 X 57 Mauser.
Likes Likes:  0
Results 1 to 7 of 7
Thread: 7 X 57 Mauser.
    Feb 2004
    Van.Isl. B.C
    68
    I have a question for the reloaders on the board. I picked up an 1898 Brazilian crested Mauser (mint in the grease) with a bayonet. This gun will be used for an unofficial military reenactment shoot at 100-yard.
    Here is my question. I would like to load this cartridge below the minimum recommended starting grains of 36 grains of IRM-3031. Would it be safe to use 30 grains of IMR-3031, using a 150-grain bullet?
    Feb 2001
    Arizona
    2,205
    339
    I think 30 grains of IMR-3031 would be a safe load but you likely will encounter erratic performance due to the large amount of air space in the case. Without knowing what velocity you are aiming for, I would recommend going with a faster powder (such as IMR-4198). The IMR loading data for 7X57 lists 29.0 gr of IMR-4198 with a 145 gr bullet at 2260 fps and 28.5 gr of IMR-4198 with a 160 gr bullet at 2135 fps. You should be able to reduce the loads by 10% without difficulty although accuracy may be less.
    Feb 2004
    Van.Isl. B.C
    68
    Thanks for your reply and the information George. Velocity is not really all that important in this case the comfort level is what I'm more interested in.
    [This message has been edited by Al Flipo (edited 04-13-2004).]
    Feb 2001
    Arizona
    2,205
    339
    I don't know how far afield you want to get with this but if you want really reduced loads, the best powder to use is SR4759. This is a powder especially designed for reduced loads. The IMR data lists a charge of 23.0 gr of SR4759 with a 145 gr bullet giving 1835 fps, which is 700 fps slower than the 3031 full power load. And again you could go 10% lower.
    Accurate Arms shows 18 gr of XMP5744 with a lead bullet but no loads with jacketed bullets.
    I use 20 gr of SR4759 in .30-06 with 180 gr bullets and 15 gr in .30-30 with 170 gr bullets so I think you would be safe with 20 gr of SR4759 with a 7mm 150 gr bullet. But this is free advice, not tested data, so you must assume the risk of using it.
    Mar 2001
    alvaton,ky
    981
    7
    35
    g gaskill
    i have a few 4# cans of 4759 left over from sheutzenfest days in the 70's if ur interested...worked well in 32-40 & 32-35 stevens ( when the lube/temp & celestial alignment were fortuitous)...not sure how to get them to calif. from ky. ........probably get them to friendship muzzle matches.....
    Feb 2001
    Arizona
    2,205
    339
    Last two cans I interstated were in checked baggage on a common carrier airline. Long before 9/11.
    I'll bet you can ship them UPS; I have received BP that way. Fedex probably also will take it.
    Happy to have it but I bet you could find a local shooter who could use it.
    Feb 2004
    Van.Isl. B.C
    68
    Thanks George, I picked up a couple cans of 4759 on a gun show yesterday, and I will loading some in the coming weeks.
